Trail gear
blarouche
SoCal
Posted in the tool section with out luck, so I thought since I'll be running my scx10 I thought I would post it here.
I want to see what everyone is using to carry their tools and spares on the trail. I'm basically using a big plastic divider box, placed in my backpack. I also carry batteries, and a spare wheel.
In the box I have 1.5mm, 2.0mm, and 2.5mm MIP drive, a nut driver for the wheels, flat, and phillips screw driver, needle nose pliers. spare c-hubs, lock outs, knuckles, drive shafts, axle rebuild kit, and dog bone axles, spur gear, pnion gear, links, rod ends, shocks, connectors, wire, misc nuts, and bolts, servo horns, AA battiers
You're doing well. I would add a bag of rod ends that's all I usually brake. We trail run on my churches golf course so I bring the wagon and set it up about halfway with cooler and parts battery etc.
I copied Rockin Wraith and use a zippered cash sack for my tools. I keep my extra screws, body pins, rod ends, etc. in a mini Altoids tin.
I use a big clear plastic divider box carried inside a bookbag (like a school bookbag like a kid would wear) strapped to my back so I can carry my rig in my hand while hiking out to the crawl spot. Inside the bookbag I also put my Radio, batteries, LiPo checker, gate markers (tennis balls cut in half), camera, .22 Pistol, snacks, and my aluminum water bottle.
In my divider box I got all the stuff off the parts tree, assorted screws, spare Tx batteries, spare rod ends, hex wrench for the wheel nut, etc.
*note* I just use the stock Axial Radio, so it nothing fancy, if I had a much nicer Radio such as a Spektrum DX I would have its own case and carry it seperate
I'm doing the same except I can strap my crawler to my bad. I have had a break too far out, too many times. Seems like I have a good base and spares. I just though my plastic been was too big but seems like what everyone else is doing.
