Oh How Original
Just built up the transmission and I have about 1.7mm of in/out play on the top shaft that the spurs on.
When it's pulled out, everything spins freely as you'd want, when it's pushed in, it's harder to turn and there's a grinding.
Obviously something isn't quite right, but I've had it apart once and put it back together exactly as the instructions say, yet the symptom is still there.
I have a longish spacer left over though, but there is nowhere it could physically fit, I do wonder if this is a common issue and what the fix is?
Just before taking it apart to inspect again.
