traxxas 2.4 tq4 with rc4wd winch
are you sure its a 3pos switch? it could be a 2pos switch..
anyways, if its a computered radio, like a DX3R, go through your settings and see if you can change the button arrangement. that could be the problem
You can mod the 2.4 TQ4 so that you can use the the toggle switch to control a winch.
You switch channels 3 and 4. Channel 4 is not 3 position capable. Channel 3 is.
Open the case and find where the 2 wires from each of the switches connect to a board in the base of the radio. Unsolder them and switch them around so that the toggle switch is wired to where the rocker switch was and vice-versa.
Now the toggle will control channel three and the rocker will control channel 4. I did this mod for my Axial TR with a Summit trans. I needed the three positions for my winch, and I use the rocker switch for shifting the trans.
thank you!!
i knew the 2pos swith could be moded but wanted it to stay stock looking so i was gunna wire ch3 to the 3pos
that way you posted is much cleaner that how i was gunna do it too :lmao:
did this today works great thanks again "thumbsup"
was a piece of cake really took like fifteen minutes to do
I have been using my tq for years that I took apart and re soldered the wires to switch the channels around and it is extremely easy to do. if need be I can take my controller apart and snap some pics. just let me know "thumbsup"
