Trouble calibrating a new BR-XL
Maxwedge
Red Hill, Pa
I am puting together a new C2 and installed the electronics last night. I have a tried and true Spek DX3C, and got a new spek 300 rx and HH BR-XL and Cobalt puller motor. I plugged everything in (sterring, esc, winch, battery) and bound the rx. Good. Then I read the instructions for the BR-XL, and followed the calibration instructions. I have foreward, and good hill hold, but no reverse. I checked and adjusted the throttle trim and still no reverse. I re-calibrated several times but no change.
I'm thinking that when I ran power through it initially to bind the rx it calibrated itself, without me doing the required foreward-till-it-beeps/flashes procedure, and it's stuck in a half-assed calibration.
I do not have a castle link. I have read the instructions over and over.
How do I "erase" the bad-accidental calibration it took so i can re-do it correctly?
it doesn't sound like calibration, it sounds like your esc is set to forward only. usually this is fixed with the castle link, but since you don't have one.... i'm not sure you can change the settings on the brxl without a castle link. best bet would be to contact holmes hobbies, or ask the lhs if they have a castle link you could use (or if they can hook it up for you).
It doesn't sound like calibration, it sounds like your ESC is set to forward only. Usually this is fixed with the Castle link, but since you don't have one.... I'm not sure you can change the settings on the BRXL without a castle link. Best bet would be to contact Holmes Hobbies, or ask the LHS if they have a Castle link you could use (or if they can hook it up for you).
+1.
Although it's for a CC ESC, I believe most of the programming is the same.... http://www.castlecreations.com/support/documents/drivers_ed_guide.pdf
Page 22...
Actual HH BR-XL manual..... http://holmeshobbies.com/Common%20files/TorqueMaster%20BR%20instruction%201.08.pdf
Okay I got a Castlelink and set it up, plugged everything into the computer (got the 2 green squares-all good), set it up (forward-brake-reverse, no reverse lock-out), and it's still the same. The lights blink like they should and the computer/program says the esc has been successfully updated, but no change. Still only foreward or brake/neutral. If I put a Rooster in everything works fine, so I'm sure it's the esc. I contacted Castle and JRH a couple days ago but no reply yet. Might just get another Rooster (or Goat) and put this guy back in the box.
OK, silly question, after you checked/redid the set-up, did you recalibrate the ESC to your RX?
Many times, this can fix issues. It's possible you still have an issue with the ESC though.
You getting green light in forwards throttle and red light in reverse? If that is the case you can send it back and we can test it out for you. There is a chance a reverse FET got damaged in shipping, it happens sometimes.
Uh, I don't think so. I did the radio calibration several times, to no good, then bought the CastleLink and tried that several times. I thought the Link would be the end-all be-all, so I haven't re-tried the simple radio cal. since.
Check that again. You may need to reverse the throttle channel if it is backwards on the lights. Then be sure the throttle trims are all the way out (120%) and redo the calibration.
After that if you don't have reverse with proper CLink programming I would say it is hardware related and not software or setup.
Sorry about the slow email response, I got a few days behind when my comm welder went down.
OKay, lights are green foreward, red in reverse. I turned the trottle all the way out (150%) for both F/R, and re-Radio-Calibrated it. No change. Then retried the castlelink setup, and still no reverse. Hmmm? I think I'm gonna send it back John, then I'll know whether the prob is mechanical or user-error.
