TRX4M canyon trail tyres
BREL
UK
could the trx4m Defenders canyon trail tyres/tires be fitted to an after market bead lock wheel rim
Probably not the bead is thicker than normal 1" tires. You could use some Traxxas deadlocks. The issue is the Traxxas rings are different to compensate for the thicker beads.
What Gramps said ^^^
They don't fit 1.0 metal. But do fit the deadbolt plastic rims.
Sent from my LG-V521 using Tapatalk
Thank you for you help, I'll get some of these rims then, if I can find them on the tinterweb
If you want to use the Canyon trails on something besides a TRX4m the Traxxas 1" deadlocks should work on others with 7mm. hexes. I think Traxxas has some plastic deadlocks that are fairly reasonable.
Can trim the inner bead, seen alot of people do it cause the canyon tires are actually really good, unlike what comes on the bronco.
Sent from my SM-S906U using Tapatalk
