~TSS~ 1.9 Rock Monster Internal Beadlocks
STANG KILLA SS
~THE SCALE SHOP~
KILLEEN TX
The Scale Shop is very proud to release our latest beadlock wheel. Three years in the making this unique wheel is modeled after the 1:1 Hutchison Rock Monster internal beadlock, and is definatly one of the baddest looking wheels on the market. Uses industry standard VP SLW hex hubs for adjustable offsets. Available in raw finish or black.
Internal beadlock design has slight weight savings over traditional beadlocks and fewer screws to assemble.
Specs:
0.75" Internal Ring Width
0.58" Backspacing
1.9 oz Weight with hardware
Mil-Spec Type II Class 2 Anodizing
Made in USA!
Whats Included:
4x Outer Wheels
4x Inner Wheels
4x Inner Rings
65x SS Socket Head Cap Screws
(VP hubs, scale hardware and scale hubs are not included)
(Disclaimer: Proline tires are do-able, but not recommended, message me for more info)
more info here:
http://www.rccrawler.com/forum/vend...tss~-1-9-rock-monster-internal-beadlocks.html
They are truly stunning in person. We mounted up set #001 last week and have been admiring them since. They basically assembled themselves with our BFG/CI DW foam combo. We installed black shcs, come with stainless. The new take on the 3 piece design is also ingenious, giving plenty of knuckle clearance and good looks.
Assembly is similar to any 3 piece wheel design with the exception of the hardware.
"thumbsup"
I really like these and would like to know the clearance on the ID of the rear ring? I'm wondering how tight the fight will be if they even go In on a set of VP rotors. I'm sure others would like to know for knuckle weights, sorry if I missed the dims anywhere but I didn't see them in your other thread either.
-Dan
EDIT: cancel that I found on the website duh... Should have looked first.
.75 ID Incase anyone else is wondering.
hey Cory,
to keep a "standard" offset with the use of SLW hubs, what offset would you recommend? .25? .35? right now i am running stock width scx10 axles with GMADE wheels. any advice you can give would be great.
if you don't give advice i can probably figure it out too ;) was just sitting here at work thinking about putting them together later tonight.
So will 225 hubs clear knuckle weights & vp high steer? I'm at work gettin ready to get busted on company Internet!!! :shock:
clears VP high steer no problem. even zero ackerman.
VP knuckle weights have a 1.6 OD and should clear with no additional plates. but i do not own knuckle weights to confirm.
"thumbsup"
Just when I thought I had all the 1.9 wheels I could ever want, along come these.
Coolest wheels yet"thumbsup""thumbsup"
