So got some more parts delivered recently. Bell crank steering parts from shapeways took about 3 weeks for delivery with the slowest shipping to Canada :mrgreen:
Doesn't look like much because they work with the GCM top plate instead of needing a top plate 3d printed.
You reuse alot of existing parts which is great because it cuts down on hunting for little pieces.
Here's an existing steering link adjusted to fit that connects the left and right steering.
I use my carpet for good background shots in majority of my photos as my RC's are all in a spare bedroom. :mrgreen:
You require M3x6x2.5 bearing for this but since I went to the GCM upright shocks you remove that exact size bearings from the cantilever setup.
Bearings installed in the bell crank parts, the tolerances are tight on these parts, defiantly well made.
Quick shot of the hole front diff removed, pretty dirty in there!
Link installed on the steering, also used some existing steering link balls from the old steering setup.
You need some m2x22mm screws that I reused from the old setup. These screws will hold the bellcrank together.
Here's another shot of the underside. Here is where the smaller shapeways parts are used, there is a flanged nut that the top screw is threaded into to.
Shot installed with the steering on the GCM plate. Looks pretty slick already!
You need a different servo horn to clear the servo since the link is installed on the backside of the horn. The horn I used is a Losi TLR1557 for 25 tooth servos.
Even with the offset in the horn it still wasn't enough so I had to bend it outwards even more so the link cleared the servo.
Here's another shot of how the steering is connecting to the knuckles.
Ran into a minor problem with rubbing. This screw was hitting the skid plate slightly so some filing on that part will fix that.
Shot of it filed. I guess I didn't file down exactly where the part hits but either way it clears now :mrgreen:
Steering is all complete and got a 1300mah 2S lipo battery that fits perfect in the front tray.
Battery all strapped down. I won't be using the front hood anymore just so its easier to change the battery out and stuff.
Well after about 200 pictures I finished what I wanted to in this post. There's no play in the steering now compared to before. I haven't test drove it yet but I can already tell it will be a big improvement. The battery upfront should improve the weight distribution better for rock bouncing on steep climbs so it's a win win situation I think.
