TxT-1 Juggernaut Gallery
heres my txt... TXTurtle.
motor- stock
tranny- stock/gd600
shafts- revo
axles- txt jb welded
chassis- stock chopped up
tires- stock for now moab XLs soon
body- some maxx truck body, i dunno
ESC- dynamite tazer
measurements
WB- 15 1/2"
GC- 4 1/8"
length- 21"
witdh- 15"
height- 9" i think
weight- heavy, not sure.
Black Betty
Black Betty TXT 1
LRP F1 ESC
Stock Motors 9 tooth pinions
Hitec 945 Servos
Custom servo mounts
Custom chasis
Cut & raised trans
Max Shafts
Trayback ute
Moab XL'S on Velocities
Custom skidplate
BEAVER
Truck base: Txt
Esc: Super Rooster
Motor(s): 55t Lathe
Servo(s):HS645MG
Trans:Txt
Axles:Txt j/b weld
Tires: stock
WB:17.5"
The Red Baron
Slighty hacked chassis
17" WB
GD600@ 85:1
Integy 45t
Novak Super Rooster
XTM x-cellarator shocks
JB weld in all the right spots
HS-645MG in back,HSC-5998TG in front
RC4WD steering knuckles
Custom shafts, skid and servo mounts
Moabs on stocks or Redrocks on X-75's
Rock pleezer slammed
M-8 with indy. rr str
my 2.2 Juggernaut
12.5" wheelbase
12" width
1.6" diff clearance
4" center clearance
2650g (5.8lbs) rtr weight
4:1 geared axles "thumbsup"
locked Tamiya Dyna Blaster tranny
aluminium tube frame
Imex All T´s and narrowed Pede rears
front servo Airtronics 94358 , rear 94161
Axi 2212-26 and Quark 33A pro car
7.4V 1250mAh lipo , enough for 30-40 minutes runtime
WHEEL BASE - 17 1/4"
TIRE DIAMETER - 7 1/2"
WIDTH - 14 1/2"
DIFF. CLEAR. - 2 3/8"
TRANNY CLEAR - 4"
TOP OF FRAME - 8 1/2"
WEIGHT - 10 LBS.
SHOCKS - SAVAGE (INTEGY)
REVO SHAFTS
LINKS - 5/16" ALUMINUM
SERVO(S) - 645MG (4WS)
BENDER - BTA SERVO MOUNTS
- SAVAGE SHOCK MOUNTS
RC4WD - GRU
- 23MM WHEEL ADAPTERS
- UPPER LINK BRACES
SHOES - PROLINE MOAB XL on COMMANDO NARROW BEADLOCKS
TXT-1
Novak EVX
Dual Venmom 3000 batts
cheap tower hobbies radio
futaba reciver
single hitec hs-645mg, soon (hs-805bb with 5cell 6v flat reviver batt pack)
Revo shafts
JB welded diffs
cut chassis
cut/raised trans
dual stock motors/ stock pinions (9 tooths in mail)
custom servo mounts
stock shocks
removed cantis
narrowed wheels (rc4wd narrow beadlocks in the mail)
cut and reversed stock tires
WB: 15.25" links flipped top to bottom
PICS: http://s20.photobucket.com/albums/b211/dirtyjeepzj/?sc=1
My skippy built txt
I got this in a trade a little bit ago and have done a few things to it since.
Narrowed and bobbed nylint body
Custom chassis/roll cage/skid
TXt tranny/unknown transfer/txt axles
Integy savage shocks
55t lathe/super rooster/JR 650
Hawaiian Txt
Hers my TXT..KEEPING IT REAL!!
Cut TXT chassis
locked axles
5955 digital servos x2
TKR2
Novak voltage regulator
RPcustoms shocks
55lathe
GD600
stock tranny clocked
The original skid plate from "Rocktopus" by Bender
Parma Tundra bod
Proline Cheyenne Beadlocks dyed w/40series MASHERS
Narrowed Axial BEadlocks w/Moab XLS
DX3
My Modified TXT-1 (after first run)
Hi all,
we have a crawler team in Hong Kong,
and now is time to post my TXT-1 here.
My TXT's
Just a few pics of my TXT's
The blue is a stock chassis/trans setup cut and modded, GD600/55t lathe, 40 series wheels/tires cut and narrowed
The grey is under construction, but it has an MFM chassis/TXT axle/Stealth trans/70T handwound.. Outside paint... Kinda like the primer look, reminds me of my first car and truck....
Let's keep the pics coming.....
Well, I was planning on building a crawler, but then I realised I had no where to actually crawl. So I spent $4000 and built a racer instead. Sold it at Xmas to build my beloved GorillaMaxx. Its all good....
well, here's mine in current trim
Wb--16.5 ish
ESC--SD
Shocks--stock, drooped
Chassis--stock, bottom cut
Tires, 40 series moabs
Wheels--proline
trans--stock with dual gd600's
motor--dual integy 55t
axles--txt rc4wd stainless shafts
Shafts--revo
radio-- futaba t3pk, rear steer on thumbwheel
Servos--Hitec HS775mg 1/4 scale
Batts--dual electrifly 3600 7 cells
-TXT-1 axels & tranny
-Ball bearings
-Home made chassis
-Home made link/shock/servo mounts
-Narrowed cheyenne beadlocks
-Integy 55T
-GD-600
-Front bta steering
-Savage shocks
-DX 3.0
-Tekin Rebel 2
-WB 440mm
-GC 95mm
My TXT
Cut chassis, 16" wheel base
55T lathe mated to a GD600 - stock trans
Narrowed and rotated 40 series Moabs on narrowed Proline wheels- custom rock rings, SS faux lugs & bead bolts
4 wheel steering, Hitech 645 servos
Proline F650 salvaged from a trade....
Needs body posts cut, and electronics finished...
txt chassis
txt axles
novak brushless
5998tg towerpro mg945
savage shocks
spectrum radio, rec
