I am wanting a set of awesome axles and was wondering if the TXT, Axial AX-10 axles or T-rex 60 axles would be best. Does anybody have a recomendation on what is the strongest. thanks a million.
thanks for all the help guys. I am building a unique truck. It will have a nitro engine and I want to build the most realistic monster truck I can which is the reason I am using solid axles. I need a strong axle to handle the power of nitro and the speed to follow. Hope this info helps to get me more info. Thanks again for all the information.
who makes an aftermarker axle guard for a txt. thanks
does anybody know who makes aftermatket gears fir a txt to change the gear ratio.thank you
does anyone know who makes aftermarket aluminum body mounts for the txt. thanks in advance
does anyone know if losi shocks off thier big monster truck (the blue ones) can be made to fit the txt. thanks a million.
anyone know who makes a really cool skid plate for a txt. thank you
what are the largest wheels that can fit on a txt. thanks
who make an after market servo mount for the txt. thanks in advance.
who make an after market knuckle for the txt, I have seen several and want the best. thanks in advance.
does any one know if rex 60 axles will fit on the txt and are they stronger. thanks
who make the best after market cvd's for the txt. thanks in advance.
I am building a Nitro TXT. I am building this just to make the baddest most realistic truck I can. I am going to use this for more the just crawling, my 4 year old and I are building this together and would like your guys input on options. I am concerned with the axles not being strong enough. Any ideas. Thanks for all the input. Rob
who make an after market extended chassis for the txt. thanks in advance.
who make after market big tie rods for the txt. thanks in advance.
who make after market uprights for the txt. thanks in advance.
