KellyC
I have three Reedy Wolfpack lipos
They are 25c 7.4v 3000mAh.
I've been using them regularly over the last two years with my and my kids SCX10s.
I always balance change the batteries and rarely store them for more than a couple weeks either fully charged or charged with the storage mode setting on my charger.
This weekend, I recently broke the batteries out to run after what was probably their longest stretch of non-use, likely 4 to 5 weeks. It's likely between the three of them, one put away fully charged and the other two partially after the last time I used them.
When I went to balance charge them this weekend, all three of them stayed on the charger well over 100 minutes and "timed out", triggering auto shut off on my charger.
With one of them I tried to discharge to see if that would work, but the charger declined it saying "incorrect voltage."
I've run dozens upon dozens of cycles on these batteries over the last couple of years, and although I've always balance charged them, I haven't been that great about putting them away in storage mode and some of the gaps between use recently have gone pretty long. So I get it if I've toasted one battery, but, what I can't figure out is it possible that all three are toast at the same time? Or am I missing something with the charging process?
I should note that after getting "timed out" during balance charging, I'll test run the batteries in our rigs and only get around 20 to 30 minutes run time which is very low compared to what we're used to. I also cooked an older AE3 ESC in my SCX10 this weekend, causing it to smoke. I initially chalked it up to being an old ESC with a ton of cycles on it, but I wonder if it's related to the batteries...
