Vertigo
Am I the only chump who gets more articulation at the RR?
I can usually figure stuff out, but this one is stumping me. Can't see the forest for the trees moment. Many of you are good puzzle-solvers and I'd welcome any opinions about it because I'm overlooking something. Probably something insanely obvious to anyone but me.
I've got 5.2" of artic on both front wheels and left rear. But the right rear has 1/2" MORE artic and for the life of me I can't figure out why.
There is no binding anywhere that I can find. I've looked until I'm cross-eyed. Not against shock caps, skid, motor can, etc. The rod ends are all square to each other and move fluidly with the articulation. I've double-checked all the links and they measure the same length in their pairs. Nothing on the chassis is bent or deformed that would cause a different mounting angle on something.
I'm running stock XR shocks with STRC caps and returned to the silicone bushings that come with the XR kit for the upper shock mts, hoping the nylon inserts (also came with the kit) in the shock mounts were causing a bind, but they weren't. RR still travels half inch higher than any of the other three.
I have been running 13mm external limiters on all four and I've even swapped them side to side to see if one of them could be the cause, but no significant difference. RR still goes 1/2" higher.
For links, I've got HB 6x101 30-degree bents for both upper sets and front lowers. Rear lowers are Crawler Innovations universal delrin lowers.
Not a big issue, but it's one of those things that's sort of driving me nuts because I can't figure it out.
What am I overlooking?
