Karl_Hungus
So, decided to build a 1/10 rally car with a center differential and belts instead of shaft. Did some thinking and drawing and ended up with this. Based on a Xray XB4 high volume differential. Put the diff case in the lathe and removed the bottom. Made a new out of 6082-T6 aluminum. Used a diff cross pin from Xray X1 so the bevel gear axle could run through the differential. The concept worked. [emoji16]
