Welcome to RCCrawler Forums.
What are the upgrades everyone does to make it run smoother, I have the mamba x, castle 3800 kv and a savox saw-1210 digital servo , 5000 3cell, proline shocks, castle motor cooler and it’s a yeti kit. Thanks for reading
What you mean smoother?
If you think about low speed/startup. Do you have the sensored or non sensored version of the motor. If non sensored, a sensored version would help. I run the HH Puller Pro R 540-L combined with the monsterX in my Yeti and it's very smooth at startup/low speed.
If sensored maybe a smaller pinion can help smoothen it up. or play with some esc settings to get it to your liking.
Definitely depends on what you mean by smoother. If it's ride characteristics then play around with different shock oils. Heavier in the rear helps a lot for the stock rear bounce and maybe stiffer springs in the front if you are bottoming out. Electronics wise I am also running a Holmes Puller Pro but the XL 3500KV version and a Holmes Trailmaster Ble Pro ESC. There are a few other little things you can do as well depending on your definition.
