ChILd_ReBoRn
So.. I was under the impression (from some YT reviews), that Vaterra comes with aluminum shocks which are pretty decent. Well. I got mine with plastic ones, and they are crap. I was trying to get them to work properly, but either I'm doing something wrong, or the shocks are before mentioned.. crap..
so.. I've added 18WT oil to the top, and the shock acts as a spring with no spring added. I compress it, it resists, and just extends out. I've compressed it all the way in, and the top cap popped off. I've examined the piston.. it has 2 tiny holes ( around 0,8mm), but one is covered by the snap ring that connects the piston rod with the .. well.. the thingy with the holes
. I was unable to expand the hole using 1,5mm drill, because it just damages the thingy. It's really tough plastic, and the hole is close to the edge.. So.. I took out a small amount of oil, and now they work correctly. The stock springs are another matter. The plastic collar connecting the top and bottom springs just grinds on the preload thread. I've exchanged the stock springs with a combination of old Tamiya springs (form the CC01), tamiya barrel springs, and stock vaterra springs.. and I managed to get some kind of a working suspension. I still think it could be better, and I think I'll order some internal spring shocks, and try them out..
in the attached movie.. you can see the rear wheel slowly dropping down to the ground.. I've made the front shocks a bit stiffer because all the weight is up front. The rig weighs in at 3,2 kg..
https://www.youtube.com/watch?v=Ed3G0uLlpis
