mik236
Hi I am running a Velineon VXL-3s with the Velineon 3500 Brushless Motor in my losi comp crawler. I started with a 17 tooth pinion and a 7.4v 5000mAh lipo. The motor and esc was running a bit hot and the rear worm drive was getting really hot. Like I could not hold my fingers on the drive shaft yoke ya to hot. also the crawling was not to bad but if I would stop on a incline it would cog very bad unless I hammer the throttle them let off once rolling. So not the best for crawling but it dose work.
I have know took the worm gears apart and cleaned them and packed them with white lithium grease. The front gears looked in good shape and the rear gears had a lot of metal shavings and some wear in the spool. It also looks like the wear is not centered, So I took one shim and moved it the side to correct it. And I also put a 11 tooth pinion on it. The cogging on a hill start is still there but a bit better and the worm gears are running just warm now and the motor & esc are also running warm now.
Well with the cogging problem. Today I was going to buy a tekin 17.5 redline sensored motor but the hobby shop was out of stock. and with taking to him he was telling me that he is not sure about using a tekin or a novak goat with my velineon esc. He said that he herd of some people using cross brands with motor / esc and they would cog or burn up.
So have any of you tried a sensored motor on the velineon ,?
or can any one please try it it you have a sensored motor and a vxl and please give some feed back?
Thank for your time, Mike
I can post pics is any one wants
