Voodoobrew
I designed much of this car in Fusion 360 (Files is here Fusion 32 ford). The body is from a fella named Ossum, and the running gear and electronics were spares I had laying around from my Axial RR10 Bomber.
Parts list:
Transmission: Standard Ax10 style but with the extended output shaft to allow for larger spur gears. I Had to do some grinding on the motor plate to move the motor out further then the stock holes would allow.
Motor: Holmes Hobbies TrailMaster Sport 550 27t
TRAILMASTER SPORT 550 27t.
Pinion gear: Robinson Racing 48P 9T
Spur gear: kimbrough 48P 96T
Drivelines: I used the plastic ones that came with the Bomber, slow crawling they last me long time.
Tires: Stock Bomber Tires - 2.2 BFGoodrich Baja T/A KR2 Tires - R35 Compound
Wheels: Stock Bomber wheels - 2.2 Walker Evans Wheels with 3d printed wheel nuts (cause I don't have any 4mm wheel nuts
Front axle: Stock ar60 bomber front axle with universal shafts, and vanquish aluminum knuckles/C-hubs.
Rear axle: Stock axle bomber ar60 rear axle with LURC FI Spool, and under-drive gears.
Steering servo: I ran the dirt cheap Power HD LW-20MG Waterproof Digital High Torque Servo but I swapped it out with a 3brc g13 ( I used the power HD as a two speed shift servo in my scx10 II).
Battery: True Spec Premium 11.1V 4500mAh 85Amps/90C.
Transmitter/Reciever: Spektrum DX5 Pro with SR210 reciever.
ESC: QuicRun WP Crawler Brushed.
Shocks: stock shocks off a scx10 II. Heavier rear springs went in the front to hold up the battery.
4 link suspension rods: I made my own using 1/4 in steel rod from a local hardware store and traxxas rod ends.
The roof is held on with magnets for easy access to candy.
