2-shot
Ok, before I get beat down, I did use the search. Been searching and reading for the last hour. I'm a little confused about putting the VP AX10 tranny case in my Wraith.
I'm a little confused about using the stock outdrives on the AX10 case. I do understand that the VP AX10 case is shorter in the rear.
I'm running MIP driveshafts on my rig.
Here's my confusion... So, if I run the VP Hurtz Dig with the VP AX10 case (which I'm planning to do anyway), I will not have to get an extended rear output shaft, correct? The VP dig will extend the rear output shaft so it's long enough.
And, my MIP driveshafts will fit correctly and work with no mods, correct?
I also read that I will have to add a bearing in the VP case. What is the bearing size I will need to add, and where does it go in the VP case?
Harley, could use your expertise on this.
I know this has been asked one way or another, through several posts. Just getting mixed info when I searched. That's why I asked again.
Thanks for your help!!!
Sent from my iPhone using Forum Runner
