Weeeee Rock buggy
distinctive pd
Subscribed Member
Utah
My pal Ammon had this chassis, i think it will be perfect fOr a 1.9 rock buggy. I'm uncertain of the OG builder but it's not too shabby. It will need a little work but Im ok with that, I LOVE DOING TOOOB WORK. This will be a quick build and ready to drive very soon... I hope!!
Full tooooob chassis
Custom dp built RC4WD D44 centers
3 link F/R
Axial drivetrain with VP Hurtz dig
On board winch
RSD shocks
Shaved 1.9 Compass tires
Modified Axial beadlocks with LURC rings
What do we have here??? any ideas?
file.php
It is a axles truss, 3 link, panhard, shock and lower link combo i brazed up the other day...
file.php
MOUNTED JUST GOTTA POP A FEW HOLES IN THE DELRIN TOOOBS. I ended up using genuine AXIAL c-channel frame for the lower link mount because when i notched it, it fit the tooob plate perfect.
file.php
file.php
file.php
NICE AND SHAVED!!!! I LOVE LURC RINGS!!!
file.php
COOL LITTLE CHASSIS DESIGNED AROUND A SCX10 SKID. ill be sandblasting the chassis as well as adding some internal braces for winch/interior. Will also replace the 6/32 hardware with alum screws.
file.php
MORE SOON!!!!
Decided against the d44 axles with their small bearing retainers im just not confident using them with dig. Using the ol trusty built scx axles.
Built a ridiculously ugly panhard 3 link axle mount
Bulletproof trans with a v1 VP dig
XR front axle width and standard rear
file.php
file.php
CHASSIS AND AXLE PANHARD MOUNTS
file.php
file.php
3LINK MOUNT FOR CHASSIS AND AXLE
file.php
file.php
file.php
I love the direction this build is heading.
Keep up the good work, what’s your plan with the servo position?
I’m slowly collecting parts for a WErock buggy myself.
Roller!
I have major plans with this rig but gotta get it running for now to do some testing in 2 weeks. There is a local group heading to So. Utah to 3 Peaks and St George to do some rock crawling on some of the best rock on the planet!!!
file.php
file.php
file.php
file.php
file.php
Love your build, I have a question. I made a custom axle and I don't have a top link mount and I need to do something like what you did and braze one. What kind of brazing stuff you use? I'm new at this kind of stuff but excited to build realistic rigs. Be the way, how is your mount mounted on? I didn't see any screws bolting it on so that's why I asked. Keep up the good work
file.php
Thanx I use a small Mapp gas torch unless I'm building small parts like trusses then I use a full size torch acetalene/oxygen setup with a very fine brazing torch!
And no this truss is not mounted to the d44 yet, just mocked up! "thumbsup"
Thanx fellas I am currently changing the shock towers and installing a flat skid. Also Adding some SSD Diamond pros cause they look perfect and so I can flip 1 diff!!"thumbsup"
Making some minor changes to the chassis and axles
Will be installing some SSD diamond pros
As far as the chassis I cut the rear bracing out to give it more of a truck look, added double shear rear shock tabs, New front shock towers, taller rear upper link mount plates.
file.php
file.php
file.php
file.php
file.php
Got some more brazing done, rear panhard mount and New front shock towers as well as a Stainless flek paint sprayed on the chassis.
file.php
Rear panhard for no reason other than its KOOL
file.php
file.php
file.php
file.php
file.php
file.php
