BJoe
No pics, but Saturday I swapped the 272R from my Drag Slash into my Stampede, which I had a grenaded transmission in it a couple years ago and had not gotten around to fixing it. Once I had the 272R in the Stampede, I pulled the blown transmission from apart to see what happened before outting it in the Slash as a placeholder. Found that some of the teeth on the idler and diff case broke off and left some sintered metal shrapnel in the RPM case. After that I just put it back together and stuck it in the Slash for now.
Sunday, I grabbed my Grave Robber Monster Wheely King to mess with the shocks, which are off the E-Savage and E-Zilla and felt those were almost the right length, but too soft. Pulled those, emptied the HPI shock fluid that came with the shocks and had in there for at least a decade at this point. Before refilling them, I pulled the shock ends off and and swapped the bump stops to under the pistons to shorten them a hair before putting them back together and refilling them with some Traxxas 50wt shock oil I had already. Feels like it should be better but I may also order the CPE sway bars if I don’t just buy some piano wire and bend my own. It still needs a motor, ESC, and Rx, which may be a JConcepts Silent Speed 13t and Spektrum 60 amp ESC/Rx combo that will work with the newer DX3 that I have.
