What kinda run time?
TrilloThrillo110
New Zealand
I currently run a Axial Scx10 with stock electronics. I get about 1-2 hours out of my 5000mah Durtrax Ni-MH. But, I'd like to put a 2S in it.
So, what sort of run time would I get out of a AE Wolfpack that's 2S and 3400mah at 35c?
And would that time be similair to if I had that same battery except with a Novak Goat 3S and Holmes TrailMaster 540 Sport?
Thanks
Trillo
You should get about the same. A lot depends on your gearing. In my scx I run a castle 4pole 7700kv on 2s and get 1.5-2hrs run time on 5000mah.
If you gear it fast it will kill your run time. regardless you should equal your nimh if not better.
I run 2 2200mah 20c 3s in parallel on a fxr 35t hd tekin motor and ran for 3 hrs and only used 2800mah also all depends on what your doing!!!
I run a GTB2, 13.5 Novak ballistic on a MaxAmps 8000 mah 2 cell pack and get over 8 hours of trail time.
