what stock offset
Zpacknrat
county of skulls in cal
what is the offset for a H10 optic?
I do not want to order and return rims that do-not fit.
so should a zero offset work? aka: wheel mounting surface mid rim. equal amounts of rim on both sides of the mount to the axle location.
or
say a 1/2 inch offset a deep dish type of rim?
3/4 of the rim farther away from the chassis
as in keep the tire far away from the chassis.
steering issues.
all i have found is talk about tire size.
Pretty much 90% of beadlocks you find today will have the hub removable, so you can adjust fitment with wider or narrow hubs. No need to keep buy wheels cause they rub a knuckle or don't fit.
If you email Vanquish they will probably give you this information. But like hillbillyrc said, get wheels with SLW-style hubs and the offset is adjustable. I installed Vanquish wheels with .350"/9mm hubs on my Optic.
Buy whatever you want, hubs to the rescue....
