what tires are best
al3x_34
United Kingdom, wales
hi i want to know what tires are the best in looking at maxx size and anything bigger. im looking for something that is good on rocks and also mudd.
thanks alex
i would go with the moabs or the boggers the boggers work great for me makin trails i drive in the woods mostly but i also just like the more scale look with them, probly better off just to get the masher 2ks
from the sound of it you are running maxx sized wheels the only tires that are worth gettin for anyterrain in the maxx size is the masher 2k;-)
well i have a set of each moabs and m2k's on here i have alot of dirt and mud and stuff like that and few rocks but i keep my m2k's on my truck the most they just work better than the moabs for me
I have 3 Different set's of tyres. Moab, Moab Xl's and Masher 2000.
I think the worst tyres I use is the Mashers 2000. I run moab xl's the most. Masher's just seem to lose grip on slick steep hills.
James
I though the 2ks were 2.2s.
"These are Masher 2000 Tires for 2.2" Truck Tires. Appropriate for front or rear wheels."
He asked for maxx sized tires.
Maxx Mashers are the Same. They just don't Say 2000...Thet use the same Compound...
Losi Zombie Max MT racing tires are awesome if ya cut the pins out of them... I run a set of those on offset Maximizers and airsoft BB's... NO foam... I can go pretty well anywhere Moabs, Mashers, LST's and all them can go and a few places they cant'...
They work well wet, dry, warm, cold, empty or loaded with wet dirt... Been using them for a year anow and even tho they're made from Losi's red compound, SUPER soft, they show VERY little signs of wear and use... Redrocks show wear SUPER fast, mashers, so so... These, however, have so little wear on thenm, you'd think they were pretty well brand new or maybe a month old...
Forgot this part tho'... Unlike other tires, these you can't run backwards as the tread lugs have a slight angle forward... They grip VERY well from that and have almost no grip when put on reversed as the lugs will slide out instead of grip...
2.2 Jordans...Are the Best..."thumbsup"
You get the height of a Maxx Tire.. 5.5in Tall and the sidewall of the 2.2 Moabs. So that makes them 2.2 Comp Legal...What more can you ask for.:lol:
so im gessing no one uses the hpi dirt klaws
I have a set of HPI dirt claws and ran them with great results. Then i got a set of Mashers and have found that they have a fair bit more traction in the terrain that i run, and they do much better in the wet stuff than the dirt claws did.
