What to lube drive shafts with?
flyboy320
Burlington, ON, Canada
After running in the snow for a short while I can hear a squeaking/squealing noise and I think it's coming from the U-joints in the drive shaft. It's a fairly new Wraith, only about 5 packs through it and I never lubed the U-joints when I built it, so after some searching here, it seems this may be a likely culprit.
What would be the best product to use to lube the joints? I know it may sound like a dumb question, but I don't just want to use regular oil in case it may attract dirt and then cause unnecessary wear. What about something like graphite spray?
I use 40w silicone shock oil.....but I also thoroughly clean and detail my machines after each and every run.
I use nothing, just let er squeak. If you put any grease on it you're just going to attract more dirt into it since it's an open air joint, and it's going to get damaged easier/faster.
Bicycle shops have special dry graphite grease that bikers use for lubing their chains but doesn't attract dirt and debris.
I also use dry film lubricant, but one based on PTFE (Teflon). Use it all over the shafts to make them slide easier over obstacles as well. (Wouldn't want to do that with graphite...)
