What will I break/need/want to do first? Everest GEN 7 Sport
davez26
Colorado Springs
I am getting close to pulling the trigger on this, and figure that maybe I plan ahead - what seems to be the things that most owners head to first after taking delivery?
Sent from my moto g power using Tapatalk
Hey Dave, I am not really sure because I do not own a Gen7 Sport, although I just pulled the trigger on a Gen7 Pro for my daughter.
From the research I have done, the additions the Pro has is well worth the extra cost if you can swing it. If not, I am sure you will have a blast with the Sport model.
Use the advanced search feature in the Redcat Crawler Forum and search Gen7 and select title only. It should yield some decent reading material.
Goo luck, have fun and be safe "thumbsup"
Front CVAs (13849,) for one. I used Gen7 Pro axles on a 4WS rig, and broke 3 universals (like, literally snapped the long part of the shaft) in the span of a few months. Also, if it has aluminum diff housings, you should be fine (maybe,) but if they're plastic, you'll blow them out quickly. I can't tell from the pics in the manual, but part #18131 looks plastic, and you will destroy them in short order. The Gen7 also has all plastic transmission gears (18129) and they're every bit as bad as the diff housings-- the plastic is too flexy. The pin spun it's way through the 20T gear on the first pack I drove. So you'll need to replace pretty much all of the gears, have a back stock of universals, and be ready for a decent amount of torque twist. It basically needs ~80 bucks dropped into it right out of the box. AFAIC, the low pricetag of the Gen7 is absolutely a false economy.
Well crap, I am hoping the Gen7 Pro I have on order for my daughter has better luck than this... I plan on putting a smaller pinion in it right out if the box to keep the speed down, as she will just be learning.
