Simon.O.
Pros and Cons
I can see the need for weight and have used wheel weights too. I have also used Nimh to power the rig and this gave me 11oz for a start. Above the axle is not ideal but it was a start.
I am now about to get my Lipos and have a few questions on weight placement.
I ran it up my test board that I use to check geometry changes and instead of the 6 Sub-C on the front axle I ran a long wire from a bench pack to the esc.
Yes it was pretty clear that I needed that weight back on the axle.
The (Nimh) weight was previously 1/2" above the axle and it crawled fine. Now I need to replace the Ni weight with lead that I have wads of.
Is there a big difference in placing that weight on the axle vs placing it in the rims.
I have done a few vector calculations and can see that any weight wrapped around the rim under the foam is similar to having all of that weight at the hub centre, or even on the axle housing.
This all applies well until we hit a serious off camber climb or a 45+ sidehill.
From there the maths gets tedious.
From a practical point of view I can see very little difference between on the axle and in the rim.
I can see it as being easier to adjust too.
Do some of you run the ballast weight on the axle housing ??
