punkuup5150
6.4 - Wheelbase:
is measured from center of axle nut to center of axle nut. The vehicle should be set down on a flat surface by the driver. The front wheel on the side that is being checked, must be pointing straight forward. At that time, the driver will then push the entire truck down to complete a full compressed suspension. Once full
compression has been made, the driver then releases the truck to return to ride height. After the truck has rebound to a self supporting ride height, a judge will then measure the wheelbase. If both sides are to be checked, all the above procedures must be duplicated.
ok now i dont see a problem with how this is to be done but i do have a problem with how it will be iinforced. my biggest problem is the cheating that can and will most likely accure. most shocks have a preload coller. these are easly tuned up and down and will be able to bring the truck back to 12.5 wb but my problem is after teching the driver may go back to his pit and losen up the preloads. thus cheating in the new rules. there are many other reason why judgeing the wheel base this way could bring back other problems and id liek to hear what everyone thinks.
my solution to the "cheating" that may happen with this is marking the shock proload collers in some form or another. one solution i was considering was a small ziptie at the top of the preload coller. thinking of this i realized that the ziptie could easly be moved. so my new solution if it becomes a problem is to get some stickers, those little round dots we all used in school u attach it to the shock body and the preload coller if the sticker is broken it is easly idetifyed and the judge can call the penelty. im more or less thinking about the allready stressfull job for on course judges and whathell they are allready put through. my only other solution is to tech before and after every run. which is going to slow down large comps. i know ive been to many comps in my area with 50+ drivers these allready take allday this is going to drag them on even longer. but enough with my rant what does everyone else have to say about this.
disclaimer-
im not here bashing our rules members have done. i just think this opens alot of open ended problems that can happen and would like to find a solution and nip any problems in the bud now so we all can enjoy the rest of the year"thumbsup"
