I have another question for you guys in this thread. Can anyone give me the pros vs cons of the TA vs a regular link? What's the good/bad of mounting the shock to the TA vs the axle? While I've been testing the length out I mounted some rtr yeti rear shocks to the axle and it's performed pretty well. Im going wraith length for sure because I can still turn off the drag brake and go bouncing around.
I was thinking about using the rear upper mount. I like how much less hang up there is with a regular link compared to the TA. Just exploring my options before I spend $50-$70 on trailing arms. I definitely like the crawl ability with the wraith length rear end over the stock length
I'm going to mess with it when I get home from work. Always sucks when ideas are going through your head but you can't actually apply them to the rig because it's not in front of you.Haha
If my setup does not work out I plan on mounting my shocks above the straight links like that but I will just weld tabs to my links.Another option to mount the shocks on the links is to run what XR10s used to have. AX80059. I was planning on trying this if needed, depending how angled my shocks would be.
After ordering the Wraith length and then finding this thread, I installed a set of Th arms I had laying around... I haven't run it yet but it seems a winner.
Has anybody put triangulated 4-links on the rear of the Bomber?
I pieced mine together from "extra parts" that were on the parts tree that came with the car.New here. Sorry for the question if I missed it from the previous pages even if I read all of it.
What will happen to the drive shaft (from CEnter diff to Rear diff) if TH lower arm and shorter upper link will be used?
Is it possible that someone will list other changes that is needed if TH arms will be used?
Looking forward to a shorter wheelbase.
Thanks.
Sent from my SM-G955U using Tapatalk
Spotted these on fleaBay. They're for the Twin Hammers clone.
https://www.ebay.com/itm/272415526334
