Wheels that fit.
Hanshotfirst
Canada
I’m looking at some injora Range Rover wheels for my trx4 and I’ve been reading that some wheels fit and some do not. The wheels in particular have the retaining ring on the inside of the wheel and the ID of the back side of the wheel is 39mm. Can any of you tr4 gurus on here say one way or another if these wheels will fit?
If this works, these are the wheels
https://www.google.ca/search?q=injo...AQ&biw=414&bih=715&dpr=2#imgrc=dzHVCk6vw1EuxM
Measure how much clearance you need.
Sent from my SM-N975U using Tapatalk
Thanks Durok, I hope that helps. I’m new to the trx platform and I’ve just begun building my kit. I could measure from the axle shaft to the top of the portal box once I’ve built but but I thought I’d tap into the knowledge in here as well.
Basically, if the wheel uses the inner ring style pictured above, it's not going to fit over portals.
Source: I've tried it.
Thanks Durok. I took a read through the trx4 wheel fitment tread. I think if I want the style of wheel I’m after, I’d have to spend mucho dollars and get cchand ones.
