...if you were going to build the axial ar44 complete kit axles and wanted a front overdrive of like +5%, what gears set would you order and use where? the kit come with a 30 tooth ring and 8 tooth pinion.
https://www.amainhobbies.com/axial-...axle-set-build-front-or-rear-axi31438/p661357
woudl it be the 30/8 out back and then this 27/8 in front?
https://www.amainhobbies.com/hot-ra...overdrive-gear-set-27t-8t-hrascxt9278/p710174
i really cant justify the price of the vanquish axles, even though i love the looks and understand they probably add some nice weight and performance gains. i know there are other ways to add performance for less money.
Really only two ratios out there for the ar44, unlike tge larger ar60’s
Anyone seen these lol...knockjocks!
The price is 50% if vanquish but you probably cant trust much more than the housing...
https://m.banggood.com/2PCS-Silver-...-110-SCX10-RC-car-p-1405494.html?rmmds=search
i would pass on those and just get the SSD diamond axles (just got a new set)... it is 100% compatible with existing scx10v2 axle components. just follow the SSD manual when building, i didn't at first and noticed my gears binding! :lmao:
