hoghead5150
ok. 3s lipo 4400mah 30c. gearing is stock in axles, 18 tooth pinion, 87 tooth spur. have tsl-sx tires and proline titus wheels with 8oz weights in each front wheel.
i burned up the stock motor, swapped in a 27 turn axial motor and burned it up within 1 pack. put in an integy pro lathe 35 turn and it lasted 2 packs. the first two motors burned up while running 2s lipo's.
no binding what so ever! checked and rechecked this. installed MIP driveshafts (by the way, the driveshaft pins are easy to get out!)
yesterday i ran a whole 3s pack thru it with no problems. BUT we were doing more scouting than crawling. we would crawl about 5 minutes and then stop for a half hour or so. today i crawled for about 10 minutes and the motor let go. this is starting to suck (altho i'm getting pretty good at swapping motors!) what i would like to know is: the motors i've used are pretty cheap is this why they keep smoking out? is my gearing way wrong? i'm looking for a crawler with a little speed. the 35 turn on 3s was good for me but flames suck!
i don't want to buy a high dollar motor and have it do the same thing, but i'm beginning to think it's the cheap motors just not having the nuts to keep up and letting me down.
