Wife's LNC
rob5059
Subscribed Member
Strafford, NH
This is my wife's Losi. It started off as an LNC; than I converted it to an LCC, and now I am putting a LNC transmission back in it. Her truck has not seen too many upgrades over the past couple of years, so I figured it was time to step it up. Over the past couple of months I have been acquiring a bunch of new and used parts so I could upgrade her truck.
This is how it sits right now:
Front axle
Losi 20 degree hubs
Losi alum knuckles
Losi HD worm & spool
Ti king pins
BMRC Ti steering link
BWD battery plate
Rear axle
Losi alum hub carrier
stock worm & spool
Losi adj upper link mount
Chassis & Suspension
LCC shock arms
LCC front lower links
DLux bent rear lower and alum upper links
Big bore shocks with DLux no pre load shock cups and rod ends, MiniT springs
Electronics
Tekin RS
Ballistic 18.5 crawler motor
14T pinion
CC BEC
7950 servo
Tires & Wheels
VP SLW V2 wheels, 850 and 600 hubs
Proline chisels with CI Double Deuce foam
I still need to find a set of knuckle weights, but other that that I am pretty happy with the way it is performing. Her priority is that I get a set of blue beadlock rings. It is funny how are priorities are different, I want function and she wants cosmetic.
