TBex
So I bought this body last year and started this project. I cut the wheelwells and the hatch on it and made some framerails. Then I lost interest due to lack of funds for the electronics, and drivetrain. Since then Ive realized how screwed up my last frame would have made the truck. So now 1 year later Im still broke but now Im broke and jobless, and have some tubing stacked away in the corner. So I got the body down and done some more cutting to it and came up with this
Oh, I might add, I made it a one piece clip
So now with the body cut, it was time to start the chassis, I bent up my 2 new tubular frame rails and put a crossmember in to set the width, then got to remembering how I needed my motor, and tranny next before I went any further with anything so I wouldnt end up with a useless chassis that I couldnt finish. At that moment I looked in the corner and saw the 1/16 Nitro Chaos from my 1/18 Nitro Late Model and thought to myself well, This shouldnt really weigh much more than that car, it had plenty of power, and the motors relatively lightweight, and its doing nothing but sitting there. So I got thinkin, and I thought that the 1/16 might be a little underpowered, but then I measured the belly of that Chaos and it just so happened to be the same width as what I had just made my frame rails. So I welded a tab to the framerails and hacked a little of the Chaos belly and bolted it on. Then I bend up a little bit of tubing for the cage, and thats where I sit at the moment. The Motor tucks rather nicely into the body, Just hope its got the power. I figure with it mounted on the Chaos belly pan it saves me alot of work fabbing a new one thats going to work the same, and there really isnt a need in spending that much time on that when that may or may not be the power of the operation when completely finished. Wont know that until its together and I get a fully op. test run. At least this way it wont be hard to change out if I dont like it. If i do use this setup though I will be changing it out for my own belly pan
Only a couple of more joints will be MIGed, The rest will be silver soldered, Im just not all too good with silver solder, although catching on quickly.
These arnt the tires I'll be running, just happened to conviently be the same diameter as what I plan on running when finished so I used them to mock up some of the rear section...
The tank will be mounted under the front clip, hence why I made it one piece, hopefully tomorrow I will get the other half of the chassis to the same point as the driver side, and get them X'ed together and the back of them tied into the chasis rails, at that point I figure would be a good time to add in rear suspension and axle so I dont add tubes to places that will need moved a touch. Then I plan to move up and tube the front clip and get it tied into the rest of the chassis, then Im going to invest alot of time into fabing this front suspension, probably going J-arm, cant decide between it or I-beam, probably going J-arm though. then add shocks, and then finish the detail tube work into the chassis shes done. Sounds simple and quick but its gonna be a longgg project. and Yes, that big, ugly, gay wing will be coming off and in its place will be 8 LEDs, 4 ambers, and 4 reds. BTW this is in 1.5 because in the end it will be on RC4wd 1.5 BFG M/Ts
