xtm crawler
crawler newbie
visalia
hey guys what do you think of the xtm crawler and what set up would be good for electrics kinda new building a bully axle based rig now but want a 1/8
You should get the super bully axles instead. I have the XTM axles and I used them for some time, but they are not something you want to have. You should use your DX7.
i have some bully axels can i make it into a longer chassi sorry all new to crawling i want super class size i think its 1/8 also how do i use the dx7 with the throttle stic for reverse
New Tubes and shafts will be needed to convert your current bully's. Still cheaper than buying new ones tho. A chassis is the easiest change, just find one you like and make the motor leads longer.
