heyok
I want to put this out for anyone that is thinking of running their steering servo at a voltage that is higher than your ESC's normal internal BEC voltage.
Put another way, if you are planning on feeding your steering servo with more than six volts, this is my suggested way to do it:
Sending power to your steering servo in this manner ensures that only the servo gets the BEC output. This means that the ESC's internal BEC can run the light loads that are normally present on the receiver and not over-stress them by feeding them more than six volts (this is assuming that the ESC's BEC is not set higher than six volts).
