Yeti proline wheel help!
lgeldof21
Canada
Having trouble getting the yeti proline wheels clamping the beads in place! Fitting to 2.2 flatiron xl tires. Any tips?
Not sure exactly what your problem is, but I just put those tires on some aluminum beadlocks and had the bead pop out when I tightened them up. I had to loosen everything and check that the bead was fully seated then tighten them up in a pattern, going slowly and a little at a time. No more problems after that. Just takes some time.
I've got proline faultline 2.2 beadlocks and SS TSL XL tires !
No problem mounting them but poping out frequently ! :shock:
I did a chamfer on the 2 sides of the inner foam, to avoid pinching them with the rings.
20150519_203450 by le varan, sur Flickr
LV
Thanks for the help! Same thing, bead popping out just as I get the ring tightened down, followed the proline YouTube that is linked by BlownChevelle. I guess will keep at it, going to try different foams too.
I have pitbull rock beast 2's and CI DW foams mounted on the faultline with no issues. I just received the Flat Iron XL's and the foams look ridiculously too big. I would look into Crawler Innovation foams which is what I'll be installing with my flat iron xl's.
Hi,
In pic, it gives this : :lmao:
:mrgreen:
LV
