Badd's 4orty 6 aka Shorty 46 Chevy parts list as of 7/20/2016 1946 Chevy body extra 46 cab (much better shape than the one on the full truck) New front bed panel and tailgate . 1950 bed sides cut down 7" in front and 5.5" in the rear . 1989 S10 reg. cab short bed as donor chassis 4.3 v6 engine new timing gear set new water pump freeze plugs cap, rotor button, wires and plugs Dorman part # 34152 A/C Eliminator New motor mounts from Napa auto 700r4 trans rebuilt and new converter New trans mount from Napa auto wiring and brain from s10 Front chassis parts that are getting replaced with new parts . Ground Force 3" drop springs AC Delco spring pads Street Edge 2" drop spindles Ac Delco inter and outer wheel bearings Dorman upper and lower control arms Parts Warehouse inter and out tie rods, sleeves, idler arm and main beam Monroe shocks sway bar bushing and bolts Brake Motive drilled and slotted rotors Brake Motive performance brake pads Rear chassis parts getting replaced with new parts . Ground Force 3" rear drop blocks 3" Summit Racing drop leaf springs Monroe Shocks 2" frame notch plates . 94 Bravada 3:73 posi rearend New wheels cylinders New drums new brake shoes new retainer and spring kit New diff cover Coker Classis 235/75/15 Cragar Delux 69 Series wheels 15x8 19 mm offset Gorilla Center Cap 3.3" Bullets Lugnut Guys CHROME BULGE ACORN M12x1.5 E-z Swap Chassis kit (to mate the 46 body to the S10 chassis The day I bought it back in early June of this year . It is a local truck and I remember it running when I was a kid . The man would ride back roads drinking beer . http://i376.photobucket.com/albums/o...pssqluzyqd.jpg http://i376.photobucket.com/albums/o...psgdpaldyx.jpg Spare cab bought in late June . 1030 mile road trip to go get it . Did it in 21 hours . http://i376.photobucket.com/albums/o...pshh512rpx.jpg http://i376.photobucket.com/albums/o...ps7rffmnif.jpg Donor truck bought local for cheap . http://i376.photobucket.com/albums/o...pss9i4p0jb.jpg Donor truck stripped and washed . http://i376.photobucket.com/albums/o...psl90kcztn.jpg Where I'm at on the build as of 9/17/15 http://i376.photobucket.com/albums/o...ps4wbiormt.jpg http://i376.photobucket.com/albums/o...psisg7moac.jpg Little more about the truck . I have named it Shorty because the wheelbase will be 108" . Down from the 115" of the stock 46 . The bed has been shortend down 7" in front of the rear fenders and 5.5" behind . More pics soon, I hope . "thumbsup" |
Re: Badd's 4orty 6 Chevy aka Shorty That looks awesome man. Are you going to keep it like a rat rod? |
Re: Badd's 4orty 6 Chevy aka Shorty beary cool old truck! sub'd "thumbsup" |
Re: Badd's 4orty 6 Chevy aka Shorty Quote:
Re: Badd's 4orty 6 Chevy aka Shorty here is little more Frame cut to narrow it to fit the body . http://i376.photobucket.com/albums/o...ps78y8brcg.jpg http://i376.photobucket.com/albums/o...ps4pwmdxpj.jpg front of the frame shortend http://i376.photobucket.com/albums/o...ps86l1s3f6.jpg cab and bed sit on the frame http://i376.photobucket.com/albums/o...pssw3ci1yz.jpg front clip and running board mockup, had to take 7" out of the running boards http://i376.photobucket.com/albums/o...psmqotvtvo.jpg front clip on, don't mind the gap between the cab and running boards . The rockers are folded under as well as the rear of the cab . http://i376.photobucket.com/albums/o...psxj9srv9w.jpg http://i376.photobucket.com/albums/o...psrlhadzs3.jpg remade the running board supports http://i376.photobucket.com/albums/o...psfip2vu4z.jpg |
Re: Badd's 4orty 6 Chevy aka Shorty Next up 3/3 drop http://i376.photobucket.com/albums/o...pswwqd4g0h.jpg new upper and lower ball joints, new tie rods set including the idler arm http://i376.photobucket.com/albums/o...psl50kj4ca.jpg http://i376.photobucket.com/albums/o...pso5xjjvus.jpg finished up all the bed supports http://i376.photobucket.com/albums/o...pscc389fy7.jpg It will come down another 1.5" when the engine trans are in . Might still lower it another 2" . I want it to ride good so not sure yet . http://i376.photobucket.com/albums/o...psuooxkauh.jpg http://i376.photobucket.com/albums/o...psejjl1rco.jpg engine mounts in, it is getting moved back 6" from stock . This should make it handle much better than stock truck . http://i376.photobucket.com/albums/o...pshqxsthez.jpg |
Re: Badd's 4orty 6 Chevy aka Shorty Got to love the versatility of the S10 frame, and the 4.3 is it the standard or the Vortech? Lookin good so far ima keep and eye on this one. |
Re: Badd's 4orty 6 Chevy aka Shorty I am going to make chassis super nice . So I pulled the truck back apart . Had the frame sandblasted and get it in primer and paint in Dec. http://i376.photobucket.com/albums/o...psejjl1rco.jpg http://i376.photobucket.com/albums/o...psyhale4g8.jpg http://i376.photobucket.com/albums/o...psaidomigz.jpg http://i376.photobucket.com/albums/o...pscvzivabv.jpg http://i376.photobucket.com/albums/o...psibn6xcv2.jpg http://i376.photobucket.com/albums/o...ps6v7jmkt8.jpg http://i376.photobucket.com/albums/o...pstkqqxtli.jpg http://i376.photobucket.com/albums/o...ps6erzeghm.jpg http://i376.photobucket.com/albums/o...pstinrdl5m.jpg I placed the order for my tires this week . I got COKER Classic Wide Whitewall Radial 235/75R15 . Oh yes we will be rolling Gangster with the big 3 1/8" white walls . I also ordered my upper/lower control arms, spring insulator, sway bar bushing/link kit, front and rear shocks and a set of 2" drop spindles . |
Re: Badd's 4orty 6 Chevy aka Shorty Looks great man! You've put some serious work in already! |
Re: Badd's 4orty 6 Chevy aka Shorty It got up to around 44 so it was not to bad out . So I busted out some parts and got to work . New upper and lower control arm on . New 2" drop spindles on with new 3" drop springs . Also got the motor mount from the kit back on . As well as the upper spring pads . My bearings did come in today but it was after I had put the tools away . My front dust shield are junk . I have tried to find new without any luck . I guess I will check a few pick -a-parts . http://i376.photobucket.com/albums/o...psz8cqazaj.jpg http://i376.photobucket.com/albums/o...pssyzxocu0.jpg http://i376.photobucket.com/albums/o...pslpimorxc.jpg |
Re: Badd's 4orty 6 Chevy aka Shorty This is going to be a sweet ride. |
Re: Badd's 4orty 6 Chevy aka Shorty Nice project, it looks like a fun one to build and one that will be a gas to drive. Its cool you knew it as a kid it has memories built in that go with it. It was a great rescue it was literally on its last legs. |
Re: Badd's 4orty 6 Chevy aka Shorty Making progress as money allows . I got the races/bearings and seals in the rotors . I got the rotors installed . I got the calipers painted and pads installed and bolted on . I also painted and reinstalled the steering box . Got the complete tie rod assembly back on . The core support bulkhead back on the frame . http://i376.photobucket.com/albums/o...pspxs9zvgv.jpg http://i376.photobucket.com/albums/o...ps0hx2hegr.jpg http://i376.photobucket.com/albums/o...psvsgiwova.jpg http://i376.photobucket.com/albums/o...ps9cqyq6xn.jpg http://i376.photobucket.com/albums/o...psgnb03331.jpg http://i376.photobucket.com/albums/o...ps3nsaohyz.jpg http://i376.photobucket.com/albums/o...psmuko460s.jpg http://i376.photobucket.com/albums/o...ps6tsoinfi.jpg |
Re: Badd's 4orty 6 Chevy aka Shorty I got the 4wd rear end from a 94 Bravada . It is 4" wider than the stock 2wd S10 . That will allow me to do away with the spacers . I order new drums, brake shoes and spring kit . I degreased and remove rust and paint from the rear end . Got it in primer and paint . Order new 3" drop leaf springs . Cleaned them up and got them in primer and paint . Also got my wheels in and got my tires mounted . Here is some pics of my progress . http://i376.photobucket.com/albums/o...pskmdpoexy.jpg http://i376.photobucket.com/albums/o...psn2rf9i24.jpg http://i376.photobucket.com/albums/o...ps7j5oa64s.jpg http://i376.photobucket.com/albums/o...psyzp5fpde.jpg http://i376.photobucket.com/albums/o...pszfpr7zww.jpg http://i376.photobucket.com/albums/o...pshsuiayux.jpg http://i376.photobucket.com/albums/o...psa2n3yvsi.jpg http://i376.photobucket.com/albums/o...pslezr5e03.jpg http://i376.photobucket.com/albums/o...ps0y1ctxcv.jpg http://i376.photobucket.com/albums/o...psricdxzsv.jpg I updated the parts list in the first post as of today . |
Re: Badd's 4orty 6 Chevy aka Shorty Small update, I got my new leaf springs in from Summit Racing . The one from The Suspension Source where the wrong ones . I cleaned up the new ones and got some primer and paint on them . I also replaced the shackle bushings in the frame . Then I worked on putting my front sway bar and new bushings on . My center caps and lug nuts also came in last week . Tomorrow I will work on the 2" frame C notch plates . "thumbsup" http://i376.photobucket.com/albums/o...psipc5d3qx.jpg http://i376.photobucket.com/albums/o...pstftrbmob.jpg http://i376.photobucket.com/albums/o...psf4wxf2vx.jpg http://i376.photobucket.com/albums/o...psffxotonp.jpg http://i376.photobucket.com/albums/o...pssj4r2vdu.jpg http://i376.photobucket.com/albums/o...psowy9rzms.jpg http://i376.photobucket.com/albums/o...ps1jmoiks1.jpg http://i376.photobucket.com/albums/o...psba9vpdyv.jpg http://i376.photobucket.com/albums/o...psi0ehcjtu.jpg http://i376.photobucket.com/albums/o...psrtnimpoa.jpg I update the parts list in the first post again . |
Re: Badd's 4orty 6 Chevy aka Shorty Looking good man! "thumbsup" |
