Tommy R's Boring Class 1 Street Truck Hey y'all, I've been accumulating parts for a few weeks and with the Scale Nationals in Montana quickly approaching, I figured I'd better get jiggy with the build. This is going to be my Class 1 Street Rig and it won't be anything special or out of the ordinary at all. It'll be a Hilux on an SCX10 chassis. Yeah, I'm a ground breaker, baby! :ror: I originally planned on going pretty far with it. Nothing too crazy, but a nice interior, divorced drivetrain, narrow/built TLT axles, and I was going to run a Felsenfest t-case which would allow me to spin one axle faster than the other. This would mean the Axial axles wouldn't be the only option to run overdrive/underdrive gear ratios. Sounded like it was going to be pretty trick, but time is running tight and as a result I decided to cancel or at least postpone some of those plans. So here's the current plan.... Axial Chassis/Drivetrain:
http://tommyr.smugmug.com/Hobby-Stuf...79_5kHKd-L.jpg I'm waiting on some more suspension parts, but in the meantime I'm working on the bodywork. The bed is nearly done, but I have to fill a bunch of holes in the body. Ugh! :roll: |
Sweet dude! I am digging the wheel and tire setup. "thumbsup"Plans for color? |
Thanks, man. :) I've got silver graphics for it and I've always envisioned it with a deep metallic red of some sort. We'll see. Paint is unfortunately a ways off still... :cry: |
Very nice ! I think i need a 1.5 yota ,too :lmao: |
should be nice! |
That's a great list of goodies you've got there !! Gonna be a sweet rig for sure. I've been tempted to do a drop bed on a few of my SCX Yota's...but the SCX chassis seems to come up a bit too high on the rear section. (compared to say...a bruiser chassis or maybe one of Generis' chassis) Alot of guys cutout their beds to allow the shock mounts to come up thru the bedfloor....but to me...that just isn't how most of your typical "street driven" trail rigs are set up. I think that you can get away with it by losing the rear shock mount hoops...and either making some that are spaced out a little bit so that they will go up and into your rear wheel tubs.....OR......you can in-board your rear shocks ...which also works well. It should work great either way....since you're going leafed on the rear. On some of my previous rigs ...that were leafed...I've always felt that it allows your shocks to have less of a role in the suspensions overall function. "thumbsup" I've even had some leafed rigs that basically just needed shocks for looks and maybe a little more side to side stability. I've had leafed trucks where I could remove my shocks inner springs...and the rig worked even better....than it did with sprung shocks ! :mrgreen: Can't wait to see some more updates on it ! ArOn |
Lol Tommy...that was the next project on my list is a 1.55" Hilux on a third SCX10. Leaf sprung and scaling everything out as much as possible. Do yall have a class for 1.55 scalers for CTXRCC? Unfortunately TXRCO doesn't have a street or scale class...we just run RCTT rigs both 1.9s and 2.2s. |
More work done on the body, but nothing picture worthy, unfortunately. I picked up some paint the other day for it. I didn't like any of the reds they had and the blue I picked up was too dark. I think I finally settled on a winner, though. Pics later... I've got nearly a rolling chassis, but I'm at a crossroads waiting for the rear leaf spring kit from RC Bros. In the meantime I may just link it like a stock SCX10 so I can continue mounting the body and such. Anyone have recommendations for some short throw shocks for the rear? I need them to fit under the drop bed. I have some Tamiya TRF dampers, but those are WAY too pricey for a crawler! :ror: |
Looks awesome Tommy.... For shocks mate try some *shudder* Yeah Racing ones off ebay. I've used them before and they actually work well (scary i know). They come in a heap of different lengths as well. Check here: http://toys.shop.ebay.com.au/Radio-C...&_sop=15&_sc=1 |
I use the metal versions of these on my drop bed yota. http://www3.towerhobbies.com/cgi-bin...?&I=LXJK79&P=7 Same ones I used on my unimog, attached to the frame rails. |
Thanks for the comments, guys. 8) Looks like I sourced some shocks locally. I've made the decision to run brushless on this truck. It's pretty new to me and I'm rather lost in making the decision on which motor to get. I'll be running a Mamba Max Pro and 3s. I'm thinking of either the Novak 18.T or the 21.5T crawler motors. Are these good choices? Any others I should consider? I want something that will generate comparable wheelspeed to a 35t brushed motor and also have a adequate torque and really good low speed control. |
I was running a 21.5 on my Wreckluse and really liked how it pushed that heavy pig around. I will be running a 18.5 in the Mog too, I really like them motors. |
You're running both Novak Crawlers? I'm leaning toward the 18.5T, but may also consider what Tekin has available. I've got some color laid down on the body now. First coat felt a bit rough and I was debating about wet sanding it. Well, I just put a second coat on and it smoothed out a ton. I'll apply one more coat and then it might be ready for clear. Still not sure if I'll wet sand it before or after the clearcoat. I'm open to suggestions. :mrgreen: Here's a pic as it sits now. The cell phone did a bad job of capturing the color and metalflake, but you'll get an idea from it... http://tommyr.smugmug.com/Hobby-Stuf...42_Yh63R-L.jpg |
nice paint job! What paint is it? |
Nice job on the color. Looks good."thumbsup" |
o man royal blue has always been my fav. thats just beautiful. and so different than every other lux out there. looks amazing Tommy |
