06-03-2011, 08:55 PM | #1 |
Pebble Pounder Join Date: Feb 2011 Location: B.C. , Canada
| 6x6 axle to axle drive shaft?
i got a cut down stock driveshaft to make the link between the 2 rear axles on my 6x6 but it doesnt seem to be long enough cause it keeps popping out under load is there some other trick to linking the 2 axles or something better to use than the stock cut down shaft ?
06-03-2011, 09:14 PM | #2 |
Building the drive shaft between the 2 rear axles gave me the most grief when I built a 6x6 last year. I ended up using traxxas metal yokes and plastic drive shafts, they ended up being super short in length. I had to limit the articulation in the rear most axle to stop the drive shaft from coming apart. This isn't the best pic but you can see the intermediate driveshaft. I sold the rig earlier this year so I can't get any more pics. |
06-03-2011, 11:15 PM | #3 |
Quarry Creeper Join Date: Aug 2009 Location: Fresno
This is something that happens to most multi-axle trucks. I have gotten around the problem by using bigger tires and spacing the axles out by that extra 1/4 inch or so you need. You may need to limit your suspension flex too. BigSki is right, traxxas pede shafts are shorter(and stronger) than axials, so try those. I just built my 3rd mulit-axle truck, and it does not have this problem, although the other two did. |
06-03-2011, 11:30 PM | #4 |
awesome thanks guys keep the ideas coming im open to all options right now |
06-04-2011, 01:32 AM | #5 |
Rock Crawler Join Date: Apr 2010 Location: America
make u a rubber sleve to go over it and that will keep it from comin out also u mad to get another and cut it longeroh yea u got any build pics
06-04-2011, 09:21 AM | #6 |
What about using a highlift drive shaft so that it can't come apart?
06-04-2011, 12:29 PM | #7 | |
not a bad idea i wonder if i cut down the highlift shaft and weld it back together that might work but welding it back together straight might be a problem though there is not much room to play with at all so i been thinking that if the rig was on 2.2's i could space out the axles a little more and have a bit more shaft on there but i wanna try and keep it on 1.9's so i am really limited to the room i have | |
06-04-2011, 01:02 PM | #8 |
Quarry Creeper Join Date: Sep 2007 Location: Colorado Springs
I put a short limiting strap on the center of my intermediate axle. Mine would pop apart going up inclines when the intermediate was drooped and the rear was compressed. Putting a strap in the center didn't hardly hurt the flex side to side but it won't let the entire axle droop fixing the problem like a charm.
06-05-2011, 10:40 AM | #9 | |
I am using 1.9 Baja Claws, though many of the polish rigs use 2.2s and are built to true 1/10th scale. 2.2s are not out of scale for such large trucks! | |
