Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Project "Tombstone" R.I.P "Rest In Pieces"
Old 10-28-2012, 03:18 PM   #1
Going Fast
mud digger's Avatar
Default Project "Tombstone" R.I.P "Rest In Pieces"
I'm building this to best perform in a G6 style event. With that in mind, this is my first custom chassis and first go at welding. This won't be a quick build by any means. And in case you were wondering where I came up with the name.... from the 1993 film "Tombstone".
Started on the frame this weekend. Chopped it up, raised the front section of the frame to better clear panhard bar and whatnot. Fabbed some quick and dirty front shock hoops and tubed the rear. Comments and advice/ opinions welcome!
mud digger is offline   Reply With Quote
Old 10-28-2012, 03:40 PM   #2
Default Re: Long Distance Blazer
interesting brace
Absurd is offline   Reply With Quote
Old 10-28-2012, 05:04 PM   #3
not bad so far , those braces should hold as long as your welds are good. whats your wheelbase gonna be?
paleblue46 is offline   Reply With Quote
Old 10-28-2012, 06:06 PM   #4
Never thought of raising the fronted. Welds look pretty good.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
adamargue is offline   Reply With Quote
Old 10-28-2012, 07:12 PM   #5
Going Fast
mud digger's Avatar
Thanks guys. I was thinking of welding some sheet metal over those braces to give them a cleaner look.
As of now the wheelbase would be a hefty 14.5 but I think i want it more like 14 or 13.5. I guess I'll see how the turning is at 14.5 first.
Old 10-29-2012, 07:20 PM   #6
Going Fast
mud digger's Avatar
Nothing special today, just some more bracing.
Old 11-01-2012, 10:49 PM   #7
Going Fast
mud digger's Avatar
Got some of the cage tacked on. Still need to finish roof, doors, sliders and rear upper tubework. And yes I know a few of the welds look like ****. But thats what a sander is for.
Old 11-02-2012, 08:23 AM   #8
Try turning your wire speed down a bit. It should help reduce some of the bigger globs and save grinding time.
Leadfoot_11 is offline   Reply With Quote
Old 11-02-2012, 11:49 AM   #9
Going Fast
mud digger's Avatar
Alright I'll try that next time, Thanks! Won't be any more updates until next week.
Old 11-02-2012, 01:59 PM   #10
this should be cool. I was really impressed with the Crawlmaro at TTC. Just take your time.
CoreyHall is offline   Reply With Quote
Old 11-30-2012, 10:56 PM   #11
Going Fast
mud digger's Avatar
Thanks Corey, I was also very glad to see Crawlmaro do as well as it did.
Some update on the chassis. Next I will tackle the "Tombstone" front bumper. Stay tuned.
Old 12-01-2012, 06:31 PM   #12
Default Re: Project "Tombstone" R.I.P "Rest In Pieces"
I weld my frame and main cagework, then I use Silver solder to solder in the small cage detail pieces. Just my personal technique thoughts.
Jeepin-Paul is offline   Reply With Quote
Old 12-02-2012, 11:41 AM   #13
Going Fast
mud digger's Avatar
Much appreciated,
I've just been tacking it all together in case I wanted to change something.
After I can get it tacked enough to make it a roller and check for clearance, I'll either braze or silver solder it.
Old 12-02-2012, 06:25 PM   #14
Going Fast
mud digger's Avatar
Couple things today, added on to the rear of the sliders, started on the Tombstone bumper, and added some supports. 1972 Chevy panels.
And a top view.
Old 12-02-2012, 06:50 PM   #15
WOOPOOW!!
Looks good dude! Crank that heat up on that welder. My welds looked like that until I cranked it up up to C and D.
Colby is offline   Reply With Quote
Old 12-02-2012, 08:02 PM   #16
Going Fast
mud digger's Avatar
Thanks man, I've had it on C, so you think I should try D?
Old 12-03-2012, 08:20 PM   #17
Wow ,you got skills that's a killer tuber . I am subscribed
Rodamis is offline   Reply With Quote
Old 12-03-2012, 08:38 PM   #18
WOOPOOW!!
If youre on c you should be fine. Slow your feed down some, and make sure when youre slingin sparks it sounds like bacon frying. The less wire you have hanging out of the gun when you start your weld the better penetration youre goimg to get.
Disclaimer: i have only been welding for a couple 6 months, i am not by any means a pro welder, just passing on what ive found to work best for me. Hope it helps buddy! Youve done a brilliant job so far, keep it up!
Old 12-03-2012, 10:49 PM   #19
Going Fast
mud digger's Avatar
Thanks Rodamis and Colby! I appreciate and note any advice I can get.
I plan to dump a fuel cell in the rear but I've seen very few that truly look scale, may be a ways down the road. Axles are in, Pics soon.
Old 12-04-2012, 07:05 PM   #20
Going Fast
mud digger's Avatar
Got the rear axle built. Vanquish scx10 housing, truss, lock outs and blue link mounts. The rc4wd red ARB diff cover hides the HD ring & pinion, hot racing spool with fast eddy bearings throughout.
Project "Tombstone" R.I.P "Rest In Pieces" - Similar Threads
4PL has great distance Killer RC Electronics 14 01-02-2011 08:52 PM
Poor distance on new DX3.0 Mule Electronics 11 10-21-2008 12:57 PM
distance in clod axle pedro Tamiya Clod Buster 1 09-02-2007 03:59 PM
esc and receiver distance Exodus Electronics 6 01-25-2007 10:24 AM
