Big Pete Alright everyone, parts are either all here or on the way so I figure it's time to get a thread started. Parts list will be as follows; Widened and stretched King Hauler cab Custom stainless tube chassis, brazed CMS Front Dlux Big Bearing wraith housings Dlux sporty front truss for the rear VP axle parts Dravtech shocks Hulksta transmission Custom T Case HH motor DCW Wheels with Locked Up rings I hate "copying" someone elses rig but the body is inspired by DesertRc/mcrawlinslow rat king. The chassis will be very different and my hood is stretched. The cab did need to be widened to meet SORRCA rules for being at least 5" wide. I got some time to get started on the body this weekend. This is my first real time playing with styrene on this level. The cab still needs a lot of work but the hood is just about done. Hopefully I can have this complete by next weekend so I can start a chassis. I started with two king hauler bodies. I needed to add at least 3/4" to the width of it but went a little more to keep it from being questionable. This will also allow me to play with different slw hubs in the future if I desire. After a bunch of cutting I wound up with this http://i238.photobucket.com/albums/f...pshwo2kxvt.jpg And with a couple hours of work it looks like this http://i238.photobucket.com/albums/f...psa6hnhd7l.jpg http://i238.photobucket.com/albums/f...ps0foh0dzq.jpg |
Re: Big Pete My first attempt at a styrene build was a 2.2 scale King Hauler 6x6. It was a fail lol. Still on my build list tho. So this has really peeked my interest. I might learn something. Subscribed. Sent from my VS995 using Tapatalk |
Re: Big Pete Quote:
Transmission, shocks, motor, rear axle truss and rear axle steering linkage arrived today. Now I can start chassis design! http://i238.photobucket.com/albums/f...ps3gdlwwux.jpg |
Re: Big Pete Nice! I'm glad to see someone else sick of the small scale big rigs. I'm about to start a very long slow build of a scratch built 1/10 scale Autocar ATF64 after my real 1:1 truck. Going to be BIG lol. Will be watching this closely. Ben |
Re: Big Pete Quote:
Had some time to play with it today. Got the rear filler panel in the cab and cut a window that matches the same heights as the rest of the windows and looks proportional IMO. Got started on the filler panel for the hole in the roof. It's currently drying with some styrene/bondene mix I use for small gap filler. My go-to method now is sanding the parts as close to fitting as possible, bonding/reinforcing the joint and filling with this stuff. Once sanded out it looks like I'll need very little actual spot putty and I won't have to worry about it popping out. Played with the trans a little. Man this thing looks sweet. I haven't seen one in a "scaler" yet (although I'm sure there's a few) and am excited to try it. I threw the only 19t pinion on it, a robinson aluminum one from my drift car. I'll need to get some steel ones on order. My gears and shafts for my t-case should be here by Friday so I can do some design work this weekend and send it off to Shapeways. http://i238.photobucket.com/albums/f...pswqctpkzt.jpg http://i238.photobucket.com/albums/f...pse4iuxuos.jpg |
Re: Big Pete Quote:
Re: Big Pete This is going to be sick! I love the concept. |
Re: Big Pete I like it! Excited to see how you do the chassis. I use a Bulldog (Berg based) trans on my C1 and C2 rigs and love it. I think the hulksta trans has a lower ratio that should work well with big tires. |
Re: Big Pete Quote:
I did manage to get the roof panel sanded and the hood is glued back on. I also wasn't happy with how the windshield support looked, somehow it was bent. So I cut it out and I'll be putting a new one in tomorrow. Once I fill the last couple holes in the roof I'll do a quick "guide goat" of primer and hopefully almost zero spot putty. My T-Case parts arrived earlier this week. I'll be designing a 3 gear case with axial 26t gears from the t-case in the scx10.2 and using the DLUX 10.2 output shafts. This will allow me to have the spacing I need between the input and output for everything to clear nicely and have counter rotating driveshafts to kill torque twist. Once the design is complete this weekend I'll get it uploaded to shapeways. Hopefully it gets here quick so I can start on the chassis since it will be a combo t-case and skid plate. http://i238.photobucket.com/albums/f...ps4t1xjjyb.jpg |
Re: Big Pete This thing is going to be so sick when finished #teamRamRod |
Re: Big Pete It was freaking hot outside today so I got the t-case and skid plate designed, uploaded and ordered. Also decided to try saving myself some headaches and designed some parts to bolt to the skid that have a "nipple" that will slide into the tube for keeping it centered while brazing. It should make it much easier than trying to drill through a tube and shapeways only wanted $11/ea to print them in stainless. Played around with some cage design as well but I didn't want to get too crazy with it, so some of the joints are sloppy, whatever, it won't be that way when I actually build it. Was more so just an opportunity to stare at it and see if I really like the concept. http://i238.photobucket.com/albums/f...ps3sjlodel.jpg http://i238.photobucket.com/albums/f...ps2qsrkwrf.jpg |
Re: Big Pete Any updates on this sweet build? |
Re: Big Pete Looks like a good start man, you've definitely peeked my interest, I've always enjoyed big rig builds. Sub'd. Sent from my SM-N920V using Tapatalk |
Re: Big Pete Quote:
Re: Big Pete Aaaaaaand resume build. I got kinda sidetracked between work and doing a transmission design for a friends C2 rig. Last round of parts came in. I did manage to get some work done on the body this weekend, but it was so minor it wasn't even worth taking pics of. This round of parts includes; 3 sets of 1.9 RB XL's in Alien Kompound to match up to a set of RBII sidewalls since they're currently too wide 3 sets of CI foams VP diff covers (may switch to stock if these get hung up) VP link mounts VP bearing caps VP VXD set (2nd set for rear axle) Hitec 7950 for rear steering, I couldn't get a 7980 to work with the dlux truss Castle WP BEC Brass Beef Tubes Fast Eddy bearings and another package of styrene so I could get to the next coupon level lol More to come soon! http://i238.photobucket.com/albums/f...pskko4664r.jpg |
Re: Big Pete wicked build, looking forward to updates. |
Re: Big Pete Minor update. Got started modding the tires, sanded on the body and built the rear axle. Tires are 1.9 Rock Beast XL's in Alien Kompound increased to 5.5" OD without foams on 2.2 RBII sidewalls. http://i238.photobucket.com/albums/f...psjinmgh4b.jpg http://i238.photobucket.com/albums/f...psogonxras.jpg http://i238.photobucket.com/albums/f...ps5x2y6tuv.jpg http://i238.photobucket.com/albums/f...psezacg8f7.jpg http://i238.photobucket.com/albums/f...pswyrs9yws.jpg http://i238.photobucket.com/albums/f...psiotfwm3r.jpg |
Re: Big Pete Minor update and revelation. I got the front axle built, started playing with them and realized that the beef tubes are rubbing on the VXD axle shafts. When assembling the rear I only spun the ring and pinion to check bind there, not once fully assembled. Whatever, I'll get them torn down and pulled out. http://i238.photobucket.com/albums/f...psfzreqllw.jpg Also was looking through my plethora of parts and found a set of SCX10 frame rails. Decided to hold these up to the body and was shocked at how good these fit. I was going to design a full chassis but may take the easier route and use these. I'm not convinced I could fab a chassis lighter than a stock c-channel one anyways. http://i238.photobucket.com/albums/f...psgfw6proj.jpg |
