Matt.k | 04-30-2008 04:33 PM | Quote:
Originally Posted by the-one1
(Post 1168011)
The ring gear is cast iron (correct me if I'm wrong), so I would replace diff with the one from an HPI rs4 3 evo. Don't forget the spider gears too for the diff action. | Actually the gears are cast aluminum, they should hold up quite well, they are similar to other offroad nitro gears used in .18 powered trucks. We do offer upgradeable machine gears that would definately hold up to even more power. For diff action you can use components from our new RTR kit, the instructions can be downloaded from our home page for parts reference.
The HPI Nitro 3 EVO uses a different gear ratio, which would be good for on road use, but might require modification to the gear housing. You would also need a stronger motor to deal with the different ratio, for a Force .15 I would recommend sticking with the stock ratio.
Thanks,
Axial |
