04-30-2008, 10:23 AM | #1 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
| Axial / Traxxas Driveshaft Interchange Info
I had a heck of a time tring to find this info and eventually got tired of looking, so I just rounded up the parts and figured it out myself. I'm sure some of you guys already know this - but I didn't and just wanted to share the info in a thread that people can search and find. Steel / Metal / Yoke 'Axial' Metal Driveshaft Yoke (1/pkg) #AX30380 $21.99 'Traxxas' Drive Yokes Steel (2/pkg) #4628X $17.99 These steel yokes for the Traxxas Stampede/Rustler are basically identical and totally interchangeable with the Axial AX-10 Scorpion! But the Traxxas parts are half the price. DriveShaft / Driveline 'Axial' Drive Shaft Set (1/pkg) #AX80011 #9.29 'Traxxas' Long Truck Half Shafts H&BE (2/Pkg) #1951 $5.79 'Traxxas' Long Truck 1/2 Shaft Pro Pak (6/Pkg) #1953 $9.29 These Driveshafts for the Traxxas Stampede/Rustler are basically identical and totally interchangeable with the Axial AX-10 Scorpion! But the Traxxas parts are half the price. The yoke dimensions are the same AND the cross pin dimensions of the u-joint are the same. So you can install Axial Driveshafts onto Traxxas Yokes OR you can install Traxxas Driveshafts onto Axial Yokes. Another thing I found out is that you can slide the Axial Male driveshaft into the Traxxas Female Driveshaft. Its a bit loose and not perfect, but it does fit! However the Traxxas Female will NOT fit the a Axial Male driveshaft. Anyways what all this means is that if you want to homebrew a driveshaft DIG setup for a Axial - you can save some $$$ by purchasing the Traxxas Stampede / Rustler driveshafts and install them on your OEM Axial yokes! and you don't have to use Traxxas Steel Yokes. Note - Traxxas E-maxx / T-mass Parts are larger, so they wil not work. Last edited by 4RnrRick; 04-30-2008 at 10:29 AM. |
05-01-2008, 09:10 PM | #2 |
Newbie Join Date: Feb 2008 Location: Beacon
This is very useful info. I need new yokes and was blown away by the $tiff price$ for Axial parts.
05-01-2008, 11:05 PM | #3 |
Quarry Creeper Join Date: May 2007 Location: Seattle
Nice. Plus the Traxxas shafts are much more durable. If you find yourself not liking that the Traxxas shafts are shorter it is very easy to make your own extended shafts. If you run your truck long you might not like the fit of the Traxxas shaft. |
05-01-2008, 11:15 PM | #4 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
You may also want to check out Jason's recent thread on installing Maxx shafts. More work, but an improvement in strength.
05-02-2008, 06:15 AM | #5 | |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
05-02-2008, 08:54 AM | #6 |
No idea on the red boxes... the pictures use-to work.
05-02-2008, 09:07 AM | #7 |
RCC Addict Join Date: Aug 2007 Location: Rohnert Park
The Traxxas parts should be used as a complete switch over ... Meaning, use Traxxas yokes with Traxxas driveshafts. For best results, do not mix with Axial parts.
05-02-2008, 09:14 AM | #8 |
Newbie Join Date: Mar 2008 Location: Santa Rosa
I agree with Jake for best fit don"t mix.
05-02-2008, 11:55 AM | #9 | |
Anyways - I don't agree with what your saying. The key is to find the best parts (strength vs price) for the application whoever the manufacture. Not sure if you trying to be a "purist" to a particluar brand - but your only wasting your money if you are trying to stick to one brand. Kinda like a Jeep with only Jeep parts will not typically be as strong as a Jeep with Jeep/Chevy/ Ford/Dana/etc... parts. | |
05-02-2008, 01:02 PM | #10 |
Pebble Pounder Join Date: Jan 2008 Location: Mission B.C. Canada
Its not about " purist" or "price" its about what works, most older axial yolks have slightly shorter cross pins than the traxxas ones and the plastic of the traxxas shafts is much stronger than the axials. If you mix an match you may be leaving a week point somewhere, shure shafts are cheap to replace but you cant replace lost points in a comp due to failure.
05-02-2008, 01:19 PM | #11 |
Quarry Creeper Join Date: Jan 2006 Location: Henderson
Jato shafts will also fit the Axial or Traxxas yokes.But the Pede shafts are just as good as the Jatos. As far as "mismatching" parts...what about those of us using traxxas yokes on Tamiya or Axial axles? The parts are "mismatched". If it works I don't care what brand name is on it. I have been running Pede shafts on the Axial yokes with no issues. If it becomes an issue,then I will put Maxx shafts on it like I did my TLT. Just my $.02 |
05-02-2008, 02:57 PM | #12 |
05-02-2008, 02:59 PM | #13 |
05-02-2008, 03:14 PM | #14 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
what happened to the pics?
05-02-2008, 03:24 PM | #15 |
I didnt measure them, didnt need too, you could actually see a difference. The axials pin sat a hair below the traxxas shafts ear holes, the traxxas pins sit a hair above the ear holes. I dont comp alot but I still dont want to have to fix broken parts on the trail either, just sayin that for those of us that want a tough trouble free rig the full traxxas setup is the way to go. I am by no means saying not to mix parts, just that it might not be the best for some of us, to each his own. The combination of too short a cross pin and the shaft plastic being too soft is why axial came out with those band aid rings. Last edited by Ax-hole; 05-02-2008 at 03:38 PM. |
05-02-2008, 04:19 PM | #16 |
Ok, so I was curious as to just how much different they are, I measured them and found that the traxxas pins are 1.4mm longer, thats quite a bit. i got my ax in december and I seem to recall someone posting that the newer kits have longer pins. Can anyone confirm this?
05-02-2008, 09:46 PM | #17 |
The pins on my Axial measure 12.75mm wide or 0.502"
05-02-2008, 10:19 PM | #18 |
ok now were talkin, I broke out the calipers and my stock axials are 0.460" so there are 2 different types out there. The traxxas are 0.510" even better but still I agree with you that you should be fine with axial yolks as long as they are the new style. Good that people can know this: check your pin lenghts if you have a prob with your mix matched drivline. |
05-03-2008, 10:50 AM | #19 |
Thats good to hear that I'm not loosing my mind....They sure looked teh same to me. 'new' pin length on axial yokes = 0.502" Traxxas pin length on steel yokes = 0.510" Thats only 0.008" overall or 0.004" each side which is just a hair more than a thickness of the hair on your head! I'm still going to say its not worth $40 to upgrade to traxxas yokes..... (well unless you have the 'old' short axial pins- then maybe.) |
05-03-2008, 05:39 PM | #20 |
I wonder "when" did axial change the pins? maybe kits manufactured "after" they released the drive shaft rings have the longer ones, so kits made after January? 4RnrRick, when did you buy your kit? |
