11-16-2008, 08:34 PM | #1 |
Pebble Pounder Join Date: Nov 2008 Location: South "O"
| rim weight
im gunna be buying a pair of mayhem enginering "7"s in black with silver "5 point" rings. i think they should weigh 5.7 OZ. should i put weights on them or leave them stock??? and should i get narrow or wide offset???
11-16-2008, 08:43 PM | #2 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
| Add about 6 oz. per wheel which is a half 0z strip. Get the narrows so that it turns sharper and fits through gates easier.
11-16-2008, 08:46 PM | #3 |
did you get the narrow??? can the hitec 645 servo handle that much weight???
11-16-2008, 08:47 PM | #4 |
11-16-2008, 08:50 PM | #5 |
im just worried about the track width being too narrow
11-16-2008, 08:52 PM | #6 |
What does mayhem say the width is on them?
11-16-2008, 08:56 PM | #7 |
the narrow track width is 10 1/4
11-16-2008, 08:56 PM | #8 |
Pebble Pounder Join Date: May 2008 Location: SoCal
11-16-2008, 09:03 PM | #9 |
ok so wide in the front and narrrow in the rear??? is that wut u run??? i just want to make sure im getting the right thing because this is such a big investment
11-16-2008, 09:05 PM | #10 |
11-16-2008, 09:05 PM | #11 |
| Well that just makes it harder to fit through gates. Regular axial offset in front and narrow rear. The problem is that you have to buy different rims.
11-16-2008, 09:14 PM | #12 |
| I run Vanquish Revolvers in the front, Fully loaded, and Comp Heavy delrin Berg Offset in the rear.(Avatar isnt updated.) Which gives me a 10" track width front, and 9 1/2" in the rear. |
11-16-2008, 09:25 PM | #13 |
so a 10 1/4 track width is fine? wut is the stock trackwidth of an ax10
11-16-2008, 09:26 PM | #14 |
11-16-2008, 09:32 PM | #15 |
ya im guna get narrows front and back
11-16-2008, 09:34 PM | #16 |
11-16-2008, 09:39 PM | #17 |
wait never mind, ENZLOW got the wide offset and he said they are only 1/8 inch wider on each side and he loves them, thanks
