11-26-2008, 03:57 AM | #1 |
Newbie Join Date: Aug 2008 Location: Greece
| Have Not Full Power Ax 10
Hello .. my ring is ax 10 with esc novak rooster, 55t motor, servo hitec 645tg, bat. 6 cell 7.2 v, radio futaba 3pm 2.4. There is the following problem: after running 10 min. something smell to me ata the electronics and since this moment have not full power.:-( What problem might be? Is there the chance for a capasitor (esc - motor) to be burnt? Thanks. |
11-26-2008, 04:05 AM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
I would have to guess either the motor or ESC. Do you have any spares to check it out? Try to clean the motor and make sure the brushes are seating right.
11-26-2008, 05:23 AM | #3 |
Pebble Pounder Join Date: May 2008 Location: Philippines
11-26-2008, 06:18 AM | #4 |
11-26-2008, 06:26 AM | #5 |
11-26-2008, 10:16 AM | #6 |
Rock Stacker Join Date: Apr 2008 Location: Windsor, VA
How old is your battery? You might want to check the voltage coming out of the battery.
11-26-2008, 11:28 AM | #7 |
Pebble Pounder Join Date: Aug 2008 Location: Indonesia - Rock Heaven
Check all wiring and connectors...probably you got short circuit somewhere...did you install the three caps provided by the rooster?
