Thread: over driven axles
Old 10-03-2009, 08:40 PM   #1
Default over driven axles
Ok, Read where some of you have overdriven axial axles....did a search and came up nothing..any help???
squatch71 is offline   Reply With Quote
Old 10-03-2009, 08:47 PM   #2
It's an overdrive gear set you have to change the ring and pinon gears. The overdive gear ratio is 36/13 and there is an underdrive gear set for the rear axle it's a 43/14 if i remember corectley. Hope this helps ya out
Rockies26 is offline   Reply With Quote
Old 10-03-2009, 08:54 PM   #3
Here's one discussion about the subject:
Axle ratios - Kit, Overdrive, Underdrive
Pete from Houston is offline   Reply With Quote
Old 10-03-2009, 09:02 PM   #4
It does...I knew what it was, but wasn't sure if I had it in my head correct
and thanks for the link..
now...where to get them???
Old 10-03-2009, 09:04 PM   #5
TSC is where i got mine
Old 10-03-2009, 09:11 PM   #6
cool, thanks I just found a set.....
