Thread: Comp crawler height?
Old 03-21-2010, 09:04 AM   #1
Default Comp crawler height?
Hey all just curious what are ur ride heights set at? From ground to bottom of chassis. I just changed my chassis and have 3" and it seems so high to me.
Cajunbrn is offline   Reply With Quote
Old 03-21-2010, 09:08 AM   #2
that is the same height as mine but the rear is 3 1/8
cascade crawler is offline   Reply With Quote
Old 03-21-2010, 10:09 AM   #3
Mines sitting at 2-1/2". Only things I have done to the suspension is 4 link the rear, big bore shocks, Axial BTA steering.
g_green is offline   Reply With Quote
Old 03-21-2010, 10:20 AM   #4
I run mine at 2.5" or lower. Just depends on your rocks. I've been on some jagged stuff and wished I was a touch taller.
TruckerBrad is offline   Reply With Quote
Old 03-21-2010, 10:51 AM   #5
D-Wray 4 Prez!
Frankenwheely's Avatar
I like mine @ 2.75" But if you got tall tires, like Rovers, I would say 2.5"
Frankenwheely is offline   Reply With Quote
Old 03-21-2010, 01:13 PM   #6
abadk9420's Avatar
Mine with Rovers is sitting at 2-7/8" and is working really well, give me enough ground clearance to get over most stuff and still side hills well to...
A couple of pics from the other day with it's current set up
abadk9420 is offline   Reply With Quote
Old 03-21-2010, 02:04 PM   #7
I run right around 2 1/2 to 2 5/8 for belly clearence. I feel that it gives me a much more stable set up, and I just employ other methods to cope with sharp break overs.
CreepyCrawl is offline   Reply With Quote
Old 03-21-2010, 04:46 PM   #8
2 5/8" to 2 3/4". Any less and breakovers are tough. Any more and sidehilling gets tough.
As low as your courses will allow.
Manning is offline   Reply With Quote
Old 03-21-2010, 07:01 PM   #9
3 5/8 VP Chassis
Bear132 is offline   Reply With Quote
Old 03-21-2010, 07:28 PM   #10
Thanx for all the responses. I am plannin on finishing off my electronics and test mid week, but I feel much more confident about my ride height. Before I was at 2 1/2" and got hung up alot. That should not be a problem anymore.
Old 03-21-2010, 07:42 PM   #11
Location: Taylors Falls just hanging with the MNRCRC crew.
Axial GC-2 with Rovers I like my skid at 2.75".
Stormin2u is offline   Reply With Quote
Old 03-21-2010, 08:53 PM   #12
FF-4 chassis, 2.75" at front of skid, 3" at rear.
DickyT is offline   Reply With Quote
