03-29-2010, 06:09 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: totowa
| best shocks for a droop setup
Well i order shocks from junfac. and made a mistake and ordered the zero shocks. Which are not a droop shock. So my question is right now i am running them with no springs but cant find an internal spring to work onthe inside of them. I am running a tcs edge chassis. Which requires you to run a droop shock. I didnt have luck running sprung at all. My stock factory shocks are beat so now i am in need of a better shock for the rig. Any suggestions would be great. |
03-30-2010, 01:39 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: florida
I'm sure they're not the best but I use 3 racing shocks with just the inner spring. I'm happy with them. I would recommend buying a couple rebuild kits with these though. |
03-30-2010, 07:19 PM | #3 |
Pebble Pounder Join Date: Nov 2009 Location: Bunbury, WA
I have the Gmade transistion in droop on my vanquish chassis and love them. no leaks and plenty of articulation
03-30-2010, 07:58 PM | #4 | |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
They will have spings. I found a box of assorted compression & extension springs for like $5. | |
03-30-2010, 07:59 PM | #5 |
I will have to check that out tomrrow. And see what i can come up with. As the full droop with no springs it is sitting a little low.
03-30-2010, 08:51 PM | #6 |
Newbie Join Date: Mar 2010 Location: Santa CRUZ
TCS has internals for like 3.99 in soft medium hard packs of 4 (crawlwell by name crawl very well by reputation) |
03-30-2010, 09:02 PM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: benton
Motorman, I bought some of those but could not get the inner springs to fit inside, It was a tight fit and had to screw the springs to get them in, but it was so tight that the shocks would not compress. did you have and problems?
