Thread: getting a click
Old 01-13-2011, 07:29 AM   #1
Default getting a click
Im getting a clicking sound that seems to be comming from the read drive shaft this is connected to the tranny. what could this be. I have taken it apart a couple times and greased and lubed everything that needs it but it still seems to be there. any ideas?
johnson21 is offline   Reply With Quote
Old 01-13-2011, 07:31 AM   #2
Check your spur gear for a little pebble.. That will make a click click noise every time the spur and pinion meet.
madkawi650 is offline   Reply With Quote
Old 01-13-2011, 08:08 AM   #3
ok I will try that, thats one place I didnt look
Old 01-13-2011, 08:39 AM   #4
And check the position of the pinion set-screw. Mine was tapping the side of the spur gear every time it went around.
Mud Puppy is offline   Reply With Quote
Old 01-13-2011, 10:49 AM   #5
ok thanks Mud I will also check that I bet you thats it.
