Thread: Axial bta kit strc 4 link
Old 01-03-2011, 10:20 PM   #1
Default Axial bta kit strc 4 link
I am running the axial bta kit on my ax10 and decided to go 4 link for Christmas. I ordered all my parts and got it all installed. Everything looks excellent and bolted up fine but it seems the bta steering rod end is hitting the STRC 4 link plate while turning left and I can't get to full lock. What did everyone who is running this setup do to fix this problem? Thanks guys for any help at all
aej_27 is offline   Reply With Quote
Old 01-03-2011, 11:03 PM   #2
Tossin' Salad
Do you mean the drag link from the servo? I shaved my STRC plate up until the two center holes for the upper links.
Casey
KC_JoNeS is offline   Reply With Quote
Old 01-04-2011, 11:19 AM   #3
Yep the drag link is hitting. That's what I figured I would have to do to the plate. Thanks
Old 02-01-2011, 11:54 PM   #4
couldn't you of flipped the drag link to the other side of the servo arm ? unless there is something there I can not see.
SmokinRocks is offline   Reply With Quote
Old 02-02-2011, 12:52 AM   #5
Tossin' Salad
no, that would be even worse. When the servo horn makes its way toward the plate, the screw or end contacts the plate....stopping movement.
Casey
Old 02-02-2011, 08:23 PM   #6
got it KC, thanks for the explanation, makes sense now.
