07-13-2011, 04:55 PM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: On the trails
| steering on ax10 rtc
I bought a ax10 rtc from a guy that has only ran it 2 times and for some reason it doesn't seem like the front wheels turn all the way like they should. I have checked everything on the truck and the radio and everything seems fine so my question is do they come stock with bad turning radius and is there a upgrade i can get to fix it. I would also like to change it over to a 4 link sus also just wondering what would be the best kit for it.
07-14-2011, 12:22 AM | #2 |
Newbie Join Date: Jun 2011 Location: Medford
The stock turning radius does leave something to be desired. To improve I would upgrade in this order: 1. Aluminum link set 2. Axial Aluminum Knuckles 3. Axial Aluminum C Hub Carrier 4. Castle Creations BEC w/ programmer 5. Better steering servo, i.e. Hitec 7950 w/ programmer The link set will remove the flex that the stock plastic steering components have. Knuckles and C hub carrier will allow a wider range of wheel turn. The stock steering servo is way under powered in my opinion, having around 90oz. of torque at 5V I believe, the Hitec 7950 has 486oz. of torque at 7.4V. The BEC will allow the servo power to come directly from the battery versus routing it through the ESC, and allows the input voltage of the servo to be user set. The programmer for the servo allows you to set your servo endpoints, etc. With this setup my wheels will turn until my tires are rubbing on the shocks, can't really get any better than that. Last edited by Doc Badger; 07-14-2011 at 12:27 AM. Reason: Added photo |
07-14-2011, 10:02 AM | #3 | |
Newbie Join Date: Apr 2011 Location: Victoria
07-14-2011, 07:31 PM | #4 | |
Aluminum knuckles and carriers are a must, but there are several choices. Some will give you more degrees of steering than others. The BEC and Castle link is a good investment. 7950 is also a good choice, though a programmer is not always needed. Having a good radio with adjustable end points is all that is needed in most cases. Tires rubbing on shocks is a subjective argument. My tires rub too, but my shocks are inboarded more than yours and I've also got more steering than you do, so yes, it does get better than that. | |
07-14-2011, 08:27 PM | #5 |
Thanks guys i will have to start getting my list together and order some goodies any suggestions on the 4 link suspension or should i leave it as 3 link |
07-14-2011, 08:31 PM | #6 |
4 link! Get one of these for the rear while you can! Scroll to the bottom! http://www.undergroundcrawlers.com/fastbackii.htm |
07-14-2011, 10:30 PM | #7 |
Read what the expert says in this thread. His comments start at post #7. How to improve turning angle on SCX? |
07-16-2011, 01:09 AM | #8 |
Newbie Join Date: Jul 2011 Location: Germany
Is there a difference in the epa of the transmitter vs the mentioned servo programmer?
07-16-2011, 02:02 AM | #9 | |
And just to clarify, I m not really an expert | |
07-19-2011, 01:43 AM | #10 |
Quarry Creeper Join Date: Apr 2011 Location: United States
It depends on how serious you wanna get. My steering is one of the most important thing to me. Heres mine and It steers even sharper now that I have made a few adjustments.
07-23-2011, 10:45 PM | #11 |
Newbie Join Date: Jul 2011 Location: salisbury
07-29-2011, 03:01 PM | #12 |
Newbie Join Date: Jul 2011 Location: catonment
alright is there anyway i can replace my servo saver with on of the steering horns they gave me with my rtc axial and Ive replaced my existing servo with the futuba s3305 thanks in advance for a reply
07-29-2011, 09:02 PM | #13 |
07-29-2011, 09:07 PM | #14 |
| yep
yea i have it just says what it comes with not how to change it out but i have figured a way to put the normal servo horn on and the turning is like 10 time better now i forsee a aluminum steering horn in my future thanks though btw you can see the steering horn i put on there in my other thread Axial RTC's Show Off Tme
